![]() | Home > Maintenance & Modifications > Adjustable height towbar - what do I need? |
Spruce Pirate Member Since: 08 Feb 2013 Location: Stirlingshire Posts: 124 ![]() ![]() ![]() |
Looking out of the window at ours it looks as though you might be able bolt it straight on, but difficult to say for sure from just looking at it. By the time you buy the receiver and the slider and pin how much do you really save on just buying the whole kit? Also ask yourself if you really need it. I tow 4 trailers on a regular basis and only adjust the height for one of them and could get away without adjusting really. It really comes into its own if you have the likes of a Sankey and a trailer with a ball/pin hitch - two sliders one with NATO coupling and one with a normal ball/pin. Height adjustment also very handy for the Sankey.
P.S. No use on dents, never repaired one in my life! Dirty Deeds - Done Dirt Cheap |
alpacaman Member Since: 07 Mar 2016 Location: Gloucestershire Posts: 160 ![]() ![]() |
Thanks. Doubt I'll save a lot on buying the whole kit. At least if I do that I then have the old one to sell to get some money back. Main reason for needing one is that I tow what is probably a home made plant trailer which has a lower than normal height hitch, and I don't really want the towbar on the 90 down low all the time.
I don't think a Dixon Bate will do want you want as the bottom of the fixed frame or ladder part will be as low as it's lowest setting. Removing the slider with the hitch on won't make it any higher. Darren
That's a fair point. You may have just saved me £100
![]() EDIT: Actually, just been looking at pics of the proper kit fitted (DA2121), and I may have misunderstood you. I'm pretty sure that with the slider at its lowest setting, and the towball bolted to the bottom two holes, it will be considerably lower than where the current one is and should do what I need. Only one way to find out I suppose... |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
DA2121 is a Britpart number. Item is DB202023 from Dixon Bates/Bradley Doublelock/Alko
If you wish to have a lowered towball consider the Nakatanenga lowered towball available here Brendan |
Yes, you can get the tow ball to be lower than the standard fixed mount. My point was though, that removing the tow ball won't get you back any clearance as the lowest point will still be the fixed DB frame. Darren
Ah OK. I see what you mean now.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785 ![]() ![]() |
I have the standard Dixon Bate adjustable jobbie on my 90 and have done for years. Can see it here:
![]() Click image to enlarge I don't find it a big problem off-road, but then I only really do greenlaning. It does knock on the odd rock step and if you are in deep ruts it can do its ploughing thing. If I was going on a big off-roading trip or something where I didn't need the towbar then I could just remove the drop plate and stays, it's only half a dozen bolts or so and it's off. |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141 ![]() ![]() ![]() |
This is a Dixon Bate slider plate,might give you some idea of low placement.
![]() Click image to enlarge For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Thanks chaps. Retroanaconda, I'm guessing the slider isn't at the lowest point on that photo? Looks like I may as well get the whole kit for £100 rather than mess around trying to fit the plate on to what I've already got.
Buy the whole kit
![]() Because if you try and just bolt the slider to the cross member without the strengthening struts/arms that bolt to the chassis you will risk buckling the rear cross member if you tow anything slightly heavy . For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
It's a hole or two up from the bottom as that suits my trailer needs.
Definitely get the whole kit. |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
I have a used kit for a 110 sitting in my garage. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Boo hoo. And you're in Norfolk too. I'm assuming a 110 version won't fit my 90?
