Home > Technical > Neutral Connection
Panda
England 2015 Defender 110 Puma 2.2 XS CSW Fuji White
Neutral Connection
Can anyone help, I have a fault on a 2015 neutral/battery connection. Seems it will not tighten sufficiently on terminal to give a good connection, can it be removed and replaced or drilled etc.
Alarm keeps going of and upsetting the neighbours total loss of power. It's hand a winch fitted by an Indy so the stealers out of the question
Cheers in advance Shocked Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Muddly XS 90 TDCI-Sold
Pearl Disco 2-Sold
Larry Disco 1-didn't want too but sold
Post #575234 3rd Nov 2016 8:02pm
leeds
Battery terminals and clamps are slightly different sizes/tapers.
Positive clamps are marked P or + whereas negative clamps are marked N or -
It might be worthwhile checking the markings on the clamps to check the correct ones have been used first.
HTH
Brendan
Post #575243 3rd Nov 2016 8:37pm
dorsetsmith
one of these if so loosen nut and with screwdriver open up slot the battery connection will now sit right down on the battery post now tighten nut up
your driver Manuel has piece on starting battery removal and alarm sounder Exclamation
Post #575249 3rd Nov 2016 8:46pm
Sometimes happens by a lot of removal and refitting.
You can either can get either a new terminal, but beware crimping them needs large tooling to do so.
Or do as I did and carefully flatten battery post with a hammer, no need to go OTT but can flatten it just enough to allow tightening of the clamp.
That's what I did and had no issues ever again, they are lead so quite easy to tap into a slightly larger profile. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #575253 3rd Nov 2016 8:47pm
Panda
Hi Brendan.
I am use to seeing the clamp type fastening connectors this one seems to be a new Land Rover design preventing auxiliary connects being made. Hence the problem
Thanks
Paul Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Pearl Disco 2-Sold
Post #575254 3rd Nov 2016 8:48pm
Panda
Custom90steve
That's sounds like a plan, see what's suggested and use your solution as a back up plan :thumbsup Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Pearl Disco 2-Sold
Post #575257 3rd Nov 2016 8:51pm
Panda
Dorsetsmith
That's the beast.
Many thanks I will try that tomorrow once everyone's up
Thanks very much,
Yoda Disco 3-Sold
Larry Disco 1-Sold
Pearl Disco 2-Sold
Post #575260 3rd Nov 2016 8:54pm
Cupboard
If you do end up needing to put new connections on, as custom90steve the crimpers are big and expensive.
However there are other options. You can solder them in or there are crimpers that you hit with a hammer which are a lot cheaper.
I have one of these, I like it and it works:
http://www.12voltplanet.co.uk/heavy-duty-s...-tool.html
If I was crimping stuff every day then I'd get the proper tool but this one does the job and and does it well.
Post #575374 4th Nov 2016 8:28am
Panda
Excellent suggestion, thank you. I willl order one today as it will be useful for the tool box anyway
Cheers cupboard Thumbs Up Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Pearl Disco 2-Sold
Post #575377 4th Nov 2016 8:36am
Cupboard
If you're buying one on the off chance you might as well pick up some terminals for it too Laughing
You can get screw on battery terminals that need no crimping as well.
Post #575391 4th Nov 2016 9:48am
Panda
Thanks again, cupboard. will do Very Happy Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Pearl Disco 2-Sold
Post #575395 4th Nov 2016 9:54am
Panda
I think I got it sorted thanks too you guys.
The original fixing both has been replace with a modified stainless bolt. Then over tightened coursing the slit to part open causing a loose connection, used a screwdriver as instructed to reopen the slit, straighten out and refit. Job Done. Alarm isolation as per hand book, worked a treat so no upset neighbours. Another plus!
Bow down Bow down Bow down Thanks Guys Monty-2015 2.2 110 XS Puma Station Wagon
Yoda Disco 3-Sold
Larry Disco 1-Sold
Pearl Disco 2-Sold
Post #575443 4th Nov 2016 2:20pm
