Home > Puma (Tdci) > LED reverse light
Page 2 of 2 <12
Martin
Site Admin
Worth a check of Fuse 10 in the battery fuse box, which is the one under the RH seat.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #574982 2nd Nov 2016 5:39pm
Steve W
Yes checked fuse was the final check I did ....... Still no joy !
Post #574992 2nd Nov 2016 6:42pm
Roy5695
I had to change the switch on mine. Not long after fitting the led reverse light too. Maybe he bulb reverse light is less sensitive than the LED unit. Cheapest place for the switch surprisingly was Land Rover. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #575027 2nd Nov 2016 9:22pm
Steve W
Ok cheers Roy I'm hoping to push through as warranty Smile
Post #575028 2nd Nov 2016 9:24pm
Steve W
Double post so deleted ......
Post #575029 2nd Nov 2016 9:24pm
dgardel
Italy
99,99% the cause is the reverse switch on the gearbox..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #575284 3rd Nov 2016 9:43pm
Steve W
Booked in dealers for this Tuesday, will let you all know what they say / find Smile
Post #575318 3rd Nov 2016 10:51pm
Page 2 of 2 <12
