Home > In Car Electronics > Double DIN Dash Issues? If you have one fitted, please help!
Page 2 of 2 <12
Edzi
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Alaska White
Good tip with the hairdryer! Thanks.
Post #565143 19th Sep 2016 7:54pm
Are the locating tabs fully home? There are two each side of the leccy windows if I remember rightly.
I think everyone else has made the right suggestions and there are obstructions etc to the rear if below.
It's a very tight fit for a single din never mind a two din. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #565146 19th Sep 2016 7:57pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
That's a good point about the tabs.
For fitting, I find it useful to leave the electric window switches hanging out so you can get a finger through to support the plastic brackets those tabs click in to. Otherwise the brackets bend back and spring forward again, pushing the facia back out. http://defender90xs.blogspot.co.uk/
Post #569510 8th Oct 2016 4:47pm
mcma1
I have had my dash apart so many times I lost the metal clips. I basically have now drilled a hole in the headunit case, and then with the clock and vents out, I attached a cable tie to the mounting hole that the support bracket (which you remove) bolts too. Pull this tight and the fascia etc all sits perfectly in line with the sides. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #569513 8th Oct 2016 4:58pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Andy,
that´s a good one. Brilliant. Thumbs Up Thumbs Up Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #569567 8th Oct 2016 10:06pm
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Bristol 90XS wrote:
It should fit absolutely flush.
I had this problem when I first had mine fitted. Issue was they hadn't bent the pipes back enough and also there are two clips in between the top switch and the window switch. Pull out the window switch and pull the clip from behind at same time as pushing the facsia in. It will clip in nicely and you will move the fascia flush. If it still doesn't go, then there must be w blockage behind. Check the pipes are out of the way and ensure they have carefully trimmed the clock off.
Pass this to your fitters and get them to fix. But it's absolutely not right and don't let them fob you off!!
Here is what it looks like:
James
gorgeous job on this!
Post #574959 2nd Nov 2016 3:40pm
Page 2 of 2 <12
