![]() | Home > Maintenance & Modifications > A frame to cross member brackets |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
are they rusted through? they are quite substantial and surface rust isn't a real problem imo 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
Raywin Member Since: 27 Feb 2015 Location: North Yorkshire Posts: 48 ![]() ![]() ![]() |
Well I spent the morning stripping the a frame and then cleaning up the bits, used the needle gun then angle grinder with wire brush and I think you are right they are not fantastic but not as bad as the looked at first, ordered new bolts for the bushes, and given the parts a coat of primer.
Going to finish them with POR 15 and put them back, give all the bolts plenty of waxoyl and hopefully if they need to come out again it won't be such a horror story. Ray |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
Yes I noticed the same and my focus recently has been to find some quickly.
So I bought a pair with arms for..............................£5.00 the pair ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Dam you never seem to spot thes things when you need them, I need to keep my eyes open now and see if I can find a set to restore prefrably with arms so I can re bush them.
Well I can hope anyway Ray |
marsie Member Since: 18 Nov 2011 Location: sheffieldish Posts: 535 ![]() ![]() ![]() |
Full a frame with chassis mounts on ebay
![]() http://www.ebay.co.uk/itm/Land-Rover-Defen...SwcLxYD8hM Paul 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE* 2004 110 TD5 Double cab. *GONE* 2010 110 2.4 XS station wagon |
