![]() | Home > Td5 > Bad MAF |
| nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 371
You will find that it's a bit gutless without a MAF at low revs. For example mine would reverse off our steep drive on tickover with a working MAF, but wouldn't with either a faulty MAF or with it unplugged. In fact that was always the first indication that the MAF was starting to fail.
The general advice is do not waste money on a cheap MAF - get a proper OEM version from a reputable supplier. Dave Green Goddess - 1998 Defender 110 300tdi |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
£70 to get a new OE, bit of a no brainer
| mustafasoleiman Member Since: 21 Jun 2016 Location: London Posts: 108
It's not a financial issue TIGER, it's curiosity to know what are the advantages and disadvantages on not having a MAF.
I will get a new good quality one as soon as I am done with my silly curiosity... NOSNIBOD has given one disadvantage: gutless at low rev... I will look for that, thank you. |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
I found that there is a bigger difference between a bad MAF and No MAF then there is between a good MAF and no MAF.
And somewhere in between you have a working MAF that doesn't give the right values. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
