![]() | Home > Maintenance & Modifications > LR Cubby Box Cup Holder Mod |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
I've never seen a square tray to replace the cup holders, so suspect it will need to be a DIY job
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5130 ![]() ![]() ![]() |
Just an idea for what it is worth, but you could easily modify the Mud UK Cubby Box 6 Switch cubby box panel to suit your requirement; a little removal of the top section would give you a neat insert to replace the standard cup holder.
Or even more easily just remove the switch panel and turn it over to fit as it does not have a bottom! And you have a neat solution. Size A: 102mm B: 250mm C: 69mm (front) ![]() http://www.youtube.com/user/conwy1 |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2064 ![]() ![]() |
Stick a bit of carpet in there.
![]() Things don't rattle so much with carpet in there rather than plastic. |
