![]() | Home > Wheels & Tyres > 285 265 and Offset |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Offset doesn't really affect the handling that much, it just affects how far (or not) things stick out. It does affect the steering lock, the stability and the amount of mud up your doors. For the most neutral handling you want the centre of the tyre around the pivot point of the steering and that's also kindest on the bearings but I don't think anyone really worries too much about that.
Suspension lift, particularly if done badly, will significantly affect the handling. Obviously you're raising the centre of gravity and also changing the steering geometry. Tyre width will affect handling, with wider tyres it will tend to wander more and be harder to steer. Wider tyres also have a higher rolling resistance (on and off road). Whatever you do, if you're using Special Tracks the handling is going to be pretty awful, I've got a friend with them and you can hear him coming from miles off too. What are you actually going to be using the vehicle for? If it's just a quarry basher then great but I'd think twice before putting them on a general purpose Land Rover. Another tyre size that might be worth considering is 255/85R16 which is the same height as the 285s but a bit narrower. That's about a 33" tall, 10" wide tyre. BFG, Maxxis and a few others do mud tyres that size that will all be more manageable on the road than Insa Turbos. Again the narrower ones might look silly in large arches though. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18047
You might want to have a read of the quote below, taken from a discussion on wheel spacers (http://www.defender2.net/forum/topic9013.html). Whilst it is about spacers, it does shed some light on the intricacies of steering geometery.
Bear in mind that all spacers do, geometrically speaking, is change the offset. 285s do and will feel different to 265s, but probably not hugely different. Generally fitting wider tyres, or otherwise altering the scrub radius, will make the vehicle more "skittish", prone to "tramlining", and suceptible to other road-surface-defect-induced odd behaviours.
And this is a classic example of why I should have just waited for an answer from blackwolf
| LANDROVER Member Since: 13 Feb 2016 Location: EAST OF ENGLAND Posts: 232
Thanks for the Reply Cupboard, Suspension is lifted slightly, I removed the blocks that had been added and it is better. I've heard the Insa Turbo Special Tracks are an amazing off road tyre & I can live with road noise. Its the handling which is important to me. I dont expect car like handling but dont want it pulling hard across road. The tyres I have now are aggressive so don't want to loose off road performance. It is mainly green lanes and a few off road events. |
| Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 850
I have had issues with handling with tyres on a 10" rim and big offset. Going to a 8" rim and less offset cured all issues. Personally I wouldn't ever drive on the road on insa turbos ever. Noise, handling and wet grip were horrendous.
Thanks Blackwolf. Hopefully I have understood this correctly. Checking the wheels I have fitted the offset is 30mm. The tyres are 13.5" wide. From a previous thread I understand my tyres are bias ply not radial....I have not got stuck yet which is nice. So...If I change to wheels with 0mm off set which I have should I fit 265/75/16 or 285/75/16..the 265's are certainly cheaper. I don't want to use spacers. The effect of scrub radius sounds like what I'am suffering
It pulls the steering with force quicker than I can react and sometimes on breaking. I have changed wheel bearings, track rod ends, drag rod ends, new drag bar and steering bar and re-tracked it. Not changed front radius arm bushes. 50-60mph is fine. Low speed is awful. Would be nice if I could try many combinations before buying! Thnaks for your advice, much appreciated. |
I spotted someone the other day with deep wheels & big tyres and asked him how his handled....badly was the answer. He had cranked arms and looked setup just still did'nt drive right. I think mine are 10" deep 30mm offset. ...I have never driven on Insa Turbos, but three people I know use them and really rate them. Two on Land Rover 90's and one a Discovery....I guess they are what they are for the price...I can live with noise but if they pull about I'm not wanting them. I guess wet grip will be low as low area in contact with road...I drive pretty steady in it to be honest....same off road I like just crawling along through the mud without having to go hard. I have some 0mm steels to fit just need to find the tyre. I think they are 8" wide wheels. What size Insa's did you have? Thanks for replying Bps, and your help. |
They were either 265 or 285 I can't remember as it was a few years back. Bias ply are not the best on the road. Are you runnning mudzillas or Treps? I'm on 35" km2's.
They are Maxis Mudzillas. Seem great off road, today & yesterday I done a track nearby very sticky and big ruts and just went through in 2nd..no wheel spinning..just drove through...thats why I really like them! I hate changing wheels about though so want one wheel/tyre for all! KM2's look nice. The Mudzillas have nice sidewall tread blocks too! Handy when its tilting over in ruts |
For green lanes I don't think you need anything more than an all terrain pattern, if the lane is bad enough to need more than that then I think you should be leaving the lane so it's not too damaged for other users and so it can recover when it dries out. Churning up public rights of way with aggressive tyres just gives the rest of us a bad name.
For off road events, depends what you're doing I guess. I've driven past vehicles on Special Tracks with my Michelin Latitudes at pay and plays, partly because I was at fairly low tyre pressures and partly because they were driving like complete idiots. I'm not saying you should buy Latitudes, from what you've said so far I don't think they're the right tyre but my point is with a bit of not being an idiot you can get further than you might think with a less aggressive tyre. I think I'd be going for the KM2s or some of the Cooper STT Pros. Both available in 315/75R16 and 285/75R16 or the KM2s in 255/85R16 for a skinnier tyre. Obviously the bigger you go (width or height) the worse it will handle, personally I don't think Defenders are heavy enough to warrant the wider tyres so I'd choose the 255s. Opinion is varied about whether or not you need a lift, some say definitely some say definitely not. I've had 255s with no lift but never got it properly articulated with them. I'm pretty sure BW doesn't have a lift and he uses 255s, plenty of others do too. Insa Turbos are not general purpose tyres, they're good pay and play tyres. |
I use 255/85 KM2s on Blindos with no lift and no problems, althoughI had to trim a tiny sliver off the inside lower edges of the rear flares. Before that I ran 285/75 KM2s on Boosts with 30mm spacers, and the steering was much less predictable.
I second what Cupboard says with one tiny modification - if your tyres are any more aggressive than KM2s then stay off unsurfaced rights of way. You will simply attract unwanted criticism fro the antis and accelerate the closure of all unsurfaced vehicular rights of way. Incidentally, the road manners of Insa Turbos are likely to be so dreadful than the offset ect is likely to be irrelevant, and their performance on wet tarmac will be marginal. I would only consider them on a vehicle which spent 90% of its time off-road on private land. |
| All times are GMT |
