Home > Puma (Tdci) > LT230 1.4 ratio on PUMA
Page 2 of 2 <12
Beery
Australia 2015 Defender 130 Puma 2.2 HCPU Corris Grey
Towing a load at 140km/h, you'd be lucky to make it to the end of that private road on a tank of fuel!
Post #572741 22nd Oct 2016 11:42pm
Okan
Switzerland 2009 Defender 110 Puma 2.4 SW Stornoway Grey
pannawonica wrote:
Okan wrote:
Nice! Are you remaped?
yes with the other usual mods, I have found 82C thermostat with the soft spring helps especially with towing! Very Happy Thumbs Up
Hi! Could you please give me the ref part of this thermostat? Is it not the same as stock?
Regards
Post #572761 23rd Oct 2016 7:53am
pannawonica
Australia
I regret that in moving house twice I cannot locate the box. However there was an extensive thread here which a search would turn up. I found it as others did well worth doing, the part is from another Land Rover discovery 2 I think! I got the one that has a soft spring, high bypass they call it I think! Thumbs Up after putting the kids too bed and couple of beers I will go back up the workshop and have a dig about if no one has enlighten us Thumbs Up Very Happy
Post #573264 25th Oct 2016 10:39am
Beery
PEL500110 for the 82c thermostat off the top of my head
Post #573434 25th Oct 2016 11:37pm
Okan
Hi all!
I m asking to all answered that they are towing with 175bhp remap on their 2.4 tdci puma. Did you feel any vibrations? Because I was going crazy about the cause of this vibrations and I just recently understood that they were coming from my remap.
Just take a look at this post.
http://www.defender2.net/forum/topic49546.html
So I m asking to you. Which kind of remap do you have on your puma? Mine is alive tuning stage 2 with bigger intercooler and it definitly doesn't work correctly as you can read in my other post because when I installed stock map back all is working fine. I'm more and more thinking that high toqrque 175remap is not compatible with heavy loaded or towing 110 Puma. Maybe something s going wrong with mine. What about yours?
Best regards
Post #584039 11th Dec 2016 10:14am
LR90XS2011
NMBRPL8 wrote:
I apologize if i derail the thread of the OP but is there a ratio option to below the stock to get taller gearing?
Itd be great to be able to sit at 130kph and chew less juice
I think Ashcroft do a higher ratio (lower number) transfer box gears, think they are from early RR auto.
Im with you my 90 would easily pull a higher gear on the road and it has a standard map (and transmission/tyres etc) if you consider all TDCIs have the same ratios and there are extremes ie 130 DCPU fully loaded with trailer etc, and 90 PU with no load.
The 90 PU would feel like a sports car in comparison to the 130, and could clearly pull a higher gear, and more relaxed higher cruising speed.
By comparison my BM 118d is 40mph/1000 revs in top gear and hence less that 2000 at 70, you can always change down to go up a steep hill DEFENDER 90 TDCI XS,
Post #584046 11th Dec 2016 10:29am
jst
if you want a bespoke Box as ^^ try Ashcroft or Rakeway. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #584056 11th Dec 2016 11:14am
Page 2 of 2 <12
