![]() | Home > Maintenance & Modifications > rear door not locking |
Do you mean if you push the door botton passenger side from outside if it's locked it'll jam and won't lock or unlock with fob? _\Hennessey|Venom| F5/___
___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 283 ![]() ![]() ![]() |
sorry , I have to use the button on the door inside the vehicle to lock/unlock that door , then i can use the fob to lock the remaining doors
I see, looks like a strip down and further investigation is in order.
Sounds a bit like an actuator. I mentioned what I did as I hadn't a similar issue with th same door but jams not won't lock or unlock. It seems a bit of an issue with passenger doors for some odd reasons. Does the door make any noise when you try to lock or unlock? _\Hennessey|Venom| F5/___ ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
broken wires on hinged rubber boot where it goes into door pillar from door that's where I would be checking first tbh 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
thanks for the replies and will have a look at the weekend now i have a starting point
pj is right. All 110 SW get that (minor) issue after a number of years. Happened to my right hand second row door last year. Dealer replaced the wire and all fine again. Actually three weeks ago same issue with my left side second row door. Need to replace that wire now, and then the same thing will happen again in five years or so. Nothing more to it.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks all .Everything working As suggested a broken wire in the rubber hinge between pillar and door .
Soldered back together then shrink wrapped ,perfect. Saved £31.31 + vat the local stealer wanted for a new one. ![]() |
Good stuff 👍👍 2008 110 2.4 XS Utility (Hagrid)
