Home > Wheels & Tyres > Spare tire |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
yes, take the wheel off and you'll see. there is bags of adjustment.
30th Jan 2011 11:05pm |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 |
cool thanks. I would assume if you dont have a big tire you wouldnt need the nuts behind the wheek
31st Jan 2011 4:27am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Mine had nuts on the studs of the carrier with large washer between the nut and the wheel. You could adjust them to get the wheel sitting correctly on the carrier. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
3rd Feb 2011 4:30pm |
cool
always something. |
3rd Feb 2011 7:13pm |
cool. I still need to take my tire off
7th Feb 2011 3:15am |
Here, I just took the tyre off to take a pic for you to show what I mean. the door is open in the pic
Click image to enlarge |
8th Feb 2011 5:17pm |
thanks
makes sense |
8th Feb 2011 6:39pm |
Finally did this today. Took my wheel off and made a few adjustments. My tire doesn't vibrate while I drive but shakes when I close the door. I didn't put washers behind the adjusters but it seemed well adjusted. I can't figure out why it vibrates when I close the door. I am running svx wheels if that matters
29th Apr 2011 3:41am |
I saw your solution but I was wondering, what you mean by the lower studs will move along with the plate? |
29th Apr 2011 3:44am |
If no washers on the back then the stud backs move and the wheel vibrates. Put washers on as in the pic I posted then tighten the nuts and the washers stop the studs moving in and out. Not much else I can say really, it's in the pic?
29th Apr 2011 11:03pm |
What do you mean though about the studs moving?
30th Apr 2011 12:32am |
If the spacer is not tight to the wheel carrier itself then there is a gap. The studs go through the back of the carrier to face outdated and there is a plate on the back to keep them in place. If you do not put on washers to fill that gap then the weight of the wheel causes the plate to flex along with the studs and the wheel will vibrate when you close the door and on bumpy tracks etc. Give it a try. Wind out the spacers half an inch and put the wheel on. Grab the wheel top and bottom and you will be able to rock it towards and away from the vehicle. The washers fill this gap and prevent the studs from traveling
30th Apr 2011 8:37am |
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 |
I've just fitted a Mantec wheel carrier and there were no stops on the three studs that come pout to hold the wheel. Therefore the wheel is sat at a strange angle and although solid and not moving, the wheel nuts aren't holding it in place.
Can these spacers be bought from somewhere like B&Q? Does anyone have an idea of the top of their heads what size nut would be required for these studes? Suppose I could just get some large washers and some nuts to hold them in place? James |
30th Apr 2011 10:45am |
I was worried when I swapped my original Boost spare for a wider Mach 5 (couldn't stretch to the cost of a fifth originally) despite being alot wider than the Boost due to the offset the wheel ended up further from the rear door, so much so I can get behind it with a sponge and clean the door easily! If you go through life with your head in the sand....all people will see is an ar5e!!
30th Apr 2011 10:52am |
