Home > Td5 > Engine temperature
leezg
Croatia
Engine temperature
Hi All
I installed this in my Defender TD5
http://www.thermomart.com/engine-watchdog-guardian-Alarm-Sensor
I put the sensor on the back of the engine oposite side than the fan, there was a free spot for a m6 screw just what I needed.
Driving, the temp rised very slowly, after 20km of driving 80-90 km/h the temperature was around 65-68 °C
Driving for another 10km it got up to 77 °C
When I drived a bit easier it dropped to 68 °C.
Why is this? Shouldn't the temp be around 90 °C?
Is my thermostat maybe open all the time?
How to know? I have a new spare thermostat but I chsnged my antifreeze a month ago and sould like to avoid throwing it away for no reason.
Thanx in advance
Post #572368 20th Oct 2016 9:04pm
roel
I don't really understand where you put the sensor. Can you put a picture here?
If you are sure you are in the coolant system, you could be on the cold side. Roel
2003 90 Td5 (2009-now)
Post #572443 21st Oct 2016 8:59am
leezg
Croatia
I found a pic of a td5
Here on the backside of the engine
The sensor is a washer, it goes on a bolt so it cant be in the coolant
Post #572448 21st Oct 2016 9:26am
Nick666
United Kingdom 1986 Defender 90 2.5 n/a Diesel SW Yellow
The difference is you're just measuring a random temperature - the system is monitored by a sensor actually inside the system - it's a bit like trying to figure out how hot your kettle is by reading a thermometer stuck on the side of it. It's not how it's done, so understandable that you're getting a totally different reading. It might be interesting but I'm afraid it's not very useful!
Post #572684 22nd Oct 2016 6:10pm
leezg
Croatia
So you want to say that I will never get a correct reading with this engine watchdog?
Post #572694 22nd Oct 2016 6:46pm
Nick666
Well it certainly won't be a number you can compare to anything else. Personally I think it looks like a rip-off - it's never going to be something that'll tell you reliably whether your engine's running too hot.
Like I said above, you're effectively trying to read the temperature of water boiling in a kettle by sticking a thermometer randomly on the outside of the kettle. You can see how that's not going to tell you the right number?
Post #572775 23rd Oct 2016 9:15am
leezg
Croatia
What if I put this coolant t piece and put it on this screw?
[URL=][/URL]
Post #572780 23rd Oct 2016 10:19am
VeeTee
Netherlands
Must say I can't share youre opinion... It is OK as long as you keep in mind that where you put the sensor affects the reading...
I have exactly the same device and bought some extra sensors and made a rotary input switch so now I can read outside temperature, engine head temp, temp just after thermostat, gearbox temperature. I normally have it to read the temperature of the thermostat housing, and I can see clearly the the temperature falling an rising when the thermostat opens and closes.
Just because the sensor is not in in coolant, the theperature does not reflect the exact coolant temperature, but is off by some degrees dependend where the sensor is attached. It is more interesting to know the rising and falling of the temperature as the engine is working hard or the the thermostat is working OK than the exact figure...
At the same time I installed this device I also installed a low coolant alarm, I modified a spare coolant reservoir cap to accept two contacts which are closed when immersed in coolant. When the contact circuit is open (no coolant) an alarm is sounded. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #572781 23rd Oct 2016 10:22am
roel
If you put it on the blue coolant sensor part that fits in the hot part off the coolant system you will get as close as it gets. I would even put some isolation around it so it won't cool due to the air flowing past it. This way you might get reasonable close to the real coolant temperature. Roel
Post #572784 23rd Oct 2016 10:34am
leezg
Croatia
Or maybe if I try to put it under the metal bleed screw?
Post #572786 23rd Oct 2016 10:37am
roel
That looks like an option if your sensor is big enough. Still I would shield it from the air that comes from the Fan. Roel
Post #572788 23rd Oct 2016 10:47am
