![]() | Home > Puma (Tdci) > The 3rd Ladybird Defender has hit 200 |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3891 ![]() ![]() |
^ Made me smile 4yr and 200K but 3 engines later....
![]() I've had my brush 10 years, 4 new heads and 6 handles.... ![]() |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785 ![]() ![]() |
Did the previous two vehicles require multiple engines also, or did they survive?
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
The TD5 did not have engine replacements but did used to eat headgaskets, almost a service item defiantly every 20thou. That Land Rover could have lasted longer but was stolen and recovered back to me but had been chassed by the police round the Birmingham motorway network till the scumbag dropped it into the arnco on a bend (Land Rovers cant take exits at 90mph) (he found out the hard way) Any way after having that sort of treatment it was never the same again and was just a constant battle overheating, blowing hoses off, headgaskets, turbo problems so I got the first puma a 57 plate 2.4.
That had an engine at 36 thou oil pump problem, the relief valve stayed shut filled the head up with oil hydraulicked the pistons on the A303 at 70mph big bang. Lots of oil smoke and fire. The 2.4 suffered constant problems with egr valves, air flow meters and turbo manifold gaskets. This vehicle is still going strong as the Ladybird company chairman now has it on his farm and tows his boat to Cornwall with it every year and occasionally takes it to his Gite in France. The 2.2 apart from the engines has been the least problematic of them all and I put that down to the stringent service regime I now have been doing for the last 100thou 6thou oil drop and filter 12 thou full service oil and all filters. I use good oil as well Millers C1 low sap its good for the dpf, never had a dpf warning light on since using it and I sit in London and M25 traffic a lot. If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
wow.
![]() noworries - what sort of miles are on the 2.4 now ? |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946 ![]() ![]() ![]() |
It's nice to see the 2.2 is capable of high mileages, but the three engines is a bit worrying! Hopefully oil changes every 6k miles should help with that!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
stobbie Member Since: 04 Dec 2015 Location: zenderen Posts: 17 ![]() ![]() ![]() |
Thats horrible!
I have used a Defender 110 300TDI as a tow car for our company. Mostly higway miles through all of Europe with a 3 tonne trailer. Sold it with 675000km's on it. Original engine, never rebuild. Only new injectors around 400.000. Even the original turbo and headgasket. A few clutches, a gearbox and some vaccuum pumps. I've replaced that with a D2 TD5, sold it at 550000 km's, no problems except for a gearbox at 250K, the aschroft one lasted only for 50K after that. Replaced it with a D3 TDV6 and sold that at 600.000. Only a EGR and some supsension arms. And a light of the airsuspension always on. But suspension worked OK. O.. and a alternator. Now a 130 2.4 at 220000, that's the worst until now. It smokes when we start it, several VCV valves, and it just doesn't sound right, but no major problems until now, but I'm always affraid to break down for some reason. but we don't make many miles now anymore.. |
