Home > Td5 > Defender Air conditioning o rings
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
Hi All
I am currently retrofitting air conditioning to my TD5 county station wagon and need to fit replacement O rings to the various pipe connections. The o rings are fitted to the compressor pipes, receiver dryer, evaporator, condenser unit etc.
I have a diagram which is attached below. This shows a number of pipes and o-rings which are listed as no 5,6,7,8,9,10 and 11.
Can I buy a an O-Ring set or can any one help with the part numbers or details of where I can buy them, thanks!
Post #571769 18th Oct 2016 1:44pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Yes you can buy metric O ring sets.
https://simplybearings.co.uk/shop/images/assets/products/kity.jpg
These should get you out of trouble! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #571804 18th Oct 2016 3:31pm
jrule
Many thanks, the ones on the there at present are a green colour, can anyone advise whether standard nitrile is ok for refrigerant.
Post #571806 18th Oct 2016 3:47pm
dorsetsmith
LR part numbers
5,6,8 JUU100480 7,9 JUU100470 10, JUU100490 11, JUU100460
or
Image result for refrigerant o ring kit
O Ring Kit [ac0013] - Ł19.95 : Sevac Ltd. Airconditioning and ...
www.aircongas.co.uk
Post #571807 18th Oct 2016 3:50pm
jrule
Brilliant many thanks chaps
Post #571829 18th Oct 2016 4:56pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Just for info - standard black O-rings are not good for aircon. Use the proper green and lube the with a bit of aircon oil. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #572218 20th Oct 2016 7:34am
jrule
Thanks MadTom seems to be different types of air con oil available on the net but any recommendations?
Post #572239 20th Oct 2016 9:39am
MadTom
Go to the garage who will fill tha gas to the aircon systém and ask for "few drops" of oil. You will hardly need more than 2 drops for each o-ring. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #572241 20th Oct 2016 9:47am
