![]() | Home > Maintenance & Modifications > Small spot of rust – any advice please |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Before you take it back under the paintwork warranty check all the other likely corrosion spots -
round the window, the window blocks, the cappings at the rear, inside the rear door bottom edge, the roof edges etc. You may as well claim for everything - most dealers will not identify/rectify other corrosion unless you point it out to them. I am certain others will add to my list of areas to check |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 472 ![]() ![]() |
Thanks folks, I will take a good look around.
I cannot remember seeing any other bits, but another good check will be done. Cheers all, Chris |
