![]() | Home > Puma (Tdci) > LT230 1.4 ratio on PUMA |
| taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663
I think a 1.4 on a Puma will make the gears very short. 1st will almost become totally redundant.
Unless your really struggling, I'd leave it as 1.2 and do the tweaks you suggested and see how it goes. Puma, on a 1.4, plus a remap etc, I think you'd quickly regret! |
Unless you're running some BIG rubber!
| Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138
I don't think running bigger tires than 33'
That's why I wanted to know if someone allready has a feedback with 1.4 ratio on puma. I don't want to regret after ordering. |
| pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568
I occasionally have the need to tow atleast (
Thanks!
The reason why I was hesitating is because I used the ratio calculator on ashcroft website. They tell that the ideal range is 2700 rpm at 70mph on 6th gear. But with the 1.2 and 33 tires is only 2269 rpm at 70mph on 6th gear. With the 1.4 and 33 tires is 2642rpm at 70 mph on 6th gear. About my personal experience on 6th gear on highway with my actual setup I was around 2000 rpm at 62 mph on 6th and around 2500 rpm at 75mph. So I m far away the ideal 2700 preconized by ashcroft. |
| NMBRPL8 Member Since: 07 Jul 2015 Location: Australia Posts: 150
I apologize if i derail the thread of the OP but is there a ratio option to below the stock to get taller gearing?
Itd be great to be able to sit at 130kph and chew less juice |
Not sure you will use less juice but there is a 1.003 ratio on ashcroft website but it s out of stock...
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
I imagine that it would be almost undrivable on normal size wheels and tyres.
The standard ratios are well matched to the TDCi engine. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8365
i regularly tow 3.5T with a 1.2 box on a 2.4puma. if the t box went with my 33" tyres i would replace with 1.2 again. mine runs outside the ideal rev range no problem at 60 on the motorway Cheers
Hi!
Do you know your rpm at 62 and 75 mph when you are towing? regards |
Been up too 140 km/h ( on a private road towing...wink.) same RPM as not towing. However I am well aware that it takes some stopping !
Nice! Are you remaped?
it actually tows better at 65 than 60 apparently as its sits in the torque range better Cheers
[quote="Okan"]Nice! Are you remaped?[/quote] yes with the other usual mods, I have found 82C thermostat with the soft spring helps especially with towing!
