![]() | Home > In Car Electronics > Rear door courtesy light switch |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
One purple wire is alarm controlled live with door open. One purple wire is permanent live and the black is earth. The rear door switch needs to be the same as the front, single wire earthed when door open. You can tee into the passenger door switch wire or there might be one running up the drivers side a pillar under the plastic trim... 2002 90 Td5 Station Wagon
Hope that makes sense? 2002 90 Td5 Station Wagon
boode Member Since: 11 Apr 2012 Location: Devon Posts: 438 ![]() ![]() ![]() |
Makes sense - but still confused
From back door an earth wire will run through door switch up to light ? Permanent live easy to wire in Purple with white line - live when door open - how do I re create this for the back door ? |
The earth wire for the trigger needs to be wired to the wire that runs to the back of one of the front door switches. Then the two purple wires need to be connected to the lamp. This way the rear lamp will come on / fade off as per the front. 2002 90 Td5 Station Wagon
![]() Click image to enlarge ![]() Click image to enlarge |
Thanks for the diagrams
