![]() | Home > Puma (Tdci) > Battery Life and recommended replacements |
My original one was replaced at 8 years.
I put an OE part in it's place. ![]() |
I've still got the original one as the main starter battery on mine, not far off 15 years old now and used every day
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
I wouldn't be too upset at 8 years, dependent on your usage cycle. The best real test is a proper drop test.
In terms of replacements, stick with a half decent brand (varta, Bosch, yuasa etc) and pick the correct rating and you'll be fine. Unless you have a winch or spend long periods of time using accessories with the engine off, then you may want to think about your options a bit more! |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
I would say genuine but i bought one to replace a 8year old original but it failed after 2 years, i swaped it for a oddasey 1700 2004 TD5 Defender 90 xs station wagon
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
Varta are tops in my book.
