![]() | Home > Maintenance & Modifications > Loose striker |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
Any clues folks ?
![]() Click image to enlarge look at the top of the striker it is thread ! may be backing nut worked loss or thread insert broken loss ? |
Pull down on the striker and tighten as you would a bolt. Even if the retaining plate has broken free, if you tighten slowly I should think it will catch and tighten the striker. Ray
Thanks chaps,
Yep , I think the nut / plate inside the bonnet section is loose or un attached , I'll try pulling down whilst turning it, Failing that I did think about trying to drill two holes on the inner bonnet but line up with the inner nut / plate, then try n put two tack welds on it ? What ya thoughts on that ? Cheers |
A bit risky as it has to line up with the striker plate at the bottom Ray
