![]() | Home > Puma (Tdci) > CAUTION! PUMA & fording |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
That is who makes it Glyn |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Yep, tried to get that extended, but you can only get there by dropping the gearbox. |
| fordy103 Member Since: 22 Dec 2010 Location: preston lancs Posts: 85
my gearbox breather comes up into the engine bay with the other ones? had this discussion before with a few people.. Mike ive got my car booked in at that place in preston to get my suspension fitted, ill ask his opinion?
cause i rang mantec and they said pumas didnt need a wading kit unless your going to windscreen height?? |
There are 3 breather pipes that terminate into the engine bay, how many do you have? |
i have 3, was assuming one was front axle, transfer box, and gearbox? who knows ?
I also have 3. Myself and the mechanic traced all to the front diff, back diff and transfer box. The gearbox one terminates somewhere on the bellhousing, so to extend it to the engine bay involves dropping the gearbox |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
I have four-the extra one is the extended breather from the fuel tank.An extended breather for the gearbox would seem like a sensible thing to have. Pity the boys at Solihull did not do it for us. 1982 88" 2.25 diesel
Would it be possible to reach it by removing the floor panels? 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
Actually you need to remove the gearbox cover. Puma 110" SW
how would you go about removing the gearbox cover then?
You need to remove the carpet or whatever you have then the gearshift knob, rubber gaiter and about 10 screws. You will have plenty of room to grab the breather pipe. Just pull it from the bellhouse (not from the gearbox!). I posted a pic some weeks ago where you can spot the pipe. Puma 110" SW
| Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000
If it was Monaco Blue, like the one in my avatar, it was probably mine! |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253
Ander, I see you have a gatesgarth video. We have permits for May
Where in lancs are you? |
Hi Mike
I'm between Preston and Blackpool - near Elswick. Whereabouts are you? I love Gatescarth, I try and drive it every year. I'm down for June this year. Fancy meeting to say hello? Stephen |
