![]() | Home > Technical > DE CAT PIPE |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
Why should you have to adapt your mudflaps? If there had been any care taken in the design of the system, it should fall into place. Those exhausts use slip joints with Mikalor/U-Clamps so you can twist each section to make fit anyway, so would have thought it would line up okay? My exhaust systems are flange jointed, and simply bolt together only one way (The right way!). Makes them much more expensive to make, but you won't get any alignment problems. ![]() |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
I have a plug with 3 wires next to the gearbox that is blanked with a plug.Is this the O2 wire?I cant find a sensor anywere near the the cat or pipe.Maybe they all do not have a O2 sensor fitted. ![]() 90 V8 SOFT TOP |
I have never seen an example of your workmanship so reserve comment! I am extremely happy with the workmanship and finish of the Griffin system as I saw one on a display stand at Douglass Motors! I also have protruding wheels hence the adaption that may be required if the mudflaps don't fit as I would wish! Sorry if I didn't make myself clear! It does appear the Griffin system sits slightly higher and I may take your hint to see if it rotates lower, thank you! If your system is much more expensive to make surely this expense is naturally passed on to the customer? I am fortunate to consider myself to have received excellent customer care, a great deal with a generous discount and a lifetime warranty on the system irrespective of who owns the vehicle! I couldn't really have expected any more! Happy days! ![]() Treat every day as if it is your last....one day you will be right!! |
A mate of mine makes exhausts - possibly the Alive tuning ones - and they fit very well, I've got one on the TR90. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Every stainless steel flange joint on my exhausts (of which there are five on the Td5/Puma 'system', exc. decat) costs around �8 each, and that's before they're TIG welded in place. It would be far cheaper for me to have the pipe simply cut and to use slip/swage joints, but that would mean using exhaust clamps which can leak, and also makes installation much more tricky. Also in the event of a warranty claim on a faulty section, you would have to dismantle a slip jointed system, where as with mine you simply unbolt the faulty section, and pop the replacement part back in, using new gaskets. I design my products to be the best they possibly can be, and if that means it costing more to make, then so be it. You'll find my exhaust prices are'nt excessive, as I still need to be competitive. The only loser is me, as inevitably I will make less profit than my competitors. ![]()
I applaud excellent service, as I'm sure does everyone else. ![]() |
Only if he lives in Macclesfield! ![]() |
Puma engined defenders do not have an O2 sensor fitted, ever. ![]() |
Thanks for clearing that up.I suppose I'll have to take it off and look inside before I order a decat pipe. ![]() 90 V8 SOFT TOP |
If there's no cat, you should hear a muted turbo whistle from the tailpipe at idle. Also the cat 'box' will sound hollow.
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 ![]() ![]() ![]() |
any chance of of a picture of you heat shield mod? fitted my exhaust today ![]() ![]() |
JJbing Member Since: 02 Dec 2012 Location: York Posts: 41 ![]() ![]() ![]() |
My truck (2007 2.4 Puma) is currently at the garage at the moment getting serviced, thought whilst it was in I would get my Alive De cat pipe fitted.. Phone call today claiming that it'll take a day an half labour potentially to fit (on and off not their main job)!!! Are they having me on or is it really that hard to fit?
Update, Told them not to bother i will find someone who are more specialised! |
3 hours max. Did mine on my front drive. Hardest bit was getting the cat out in one piece.
I thought as much, they either don't want to do it or are trying it on!
It is now obviously an MOT fail so as with builders if they price themselves out of the market so they won't have to do it. Also there will be no recriminations for them come MOT time perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
