Home > Technical > DE CAT PIPE
Page 3 of 5 <12345>
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Got a pipe from Twisted, from the cat back, basically straight through and sounds great, little difference at idle, bit more burbly perhaps, but under load it BARKS!!
Post #46104 23rd Nov 2010 10:54pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
landy andy wrote:
Are you talking about a Tdci, as Td4 are freelander engines Question Question Question
Andy
Hi Andy,
Indeed, I'm talking about the Tdci a.ka. Puma engine Wink.
Sorry for the confusion but I see in many places this model also being referred to as Td4 and as I also own a Td5 I tend to use this to identify my Defender Laughing Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #46208 24th Nov 2010 7:29pm
Naks
n00b question - how do u know if your landy has a Cat or not? Rolling Eyes
Post #51954 9th Jan 2011 12:28pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
If it goes meow when you start it up Rolling with laughter Rolling with laughter
If you look where the exhaust meets the manifold / turbo... there should be a cat...one of these
If the cat has been removed it will look like this Thumbs Up
 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #51955 9th Jan 2011 12:34pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
I have heard that the non-cat Defenders still have the cat box but it's empty inside. Rolling Eyes Puma 110 SW
90 V8 SOFT TOP
Post #52257 10th Jan 2011 9:23pm
Naks
According to my VIN number, my Puma should not have a cat. But there is a cat box under the heat shield.
Someone else has told me that it is empty - LR uses the same parts in order to cut costs.
So, how do I check if the cat box is empty!???
Post #54475 22nd Jan 2011 6:31am
K9F
I've just purchased a Griffin Stainless System, comes in four parts, lifetime warranty, detached stainless hangers so can be finely adjusted, decat pipe, no backbox and the centre box inlet and outlet pipes are straight not staggered/offset! The quality is absolutely superb, too busy at the moment as am away in dry dock to get it fitted but have arranged for the supplier to fit for the princely sum of �100! Takes a couple of hours to fit and front propshaft has to be dropped to facilitate removal of old cat (don't want it cut grinded to get it off). Will let you know how it performs/sounds! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #54508 22nd Jan 2011 12:13pm
fekete
Make sure they put the heat shield back on around the turbo NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #54511 22nd Jan 2011 12:22pm
K9F
Thanks!! It is Douglass Motors who are going to fit it, they have just done one on their TD5 project vehicle that they just spent �15k on fitting every conceivable extra (need a stepladder just to see inside). Had to go see them to get my spare tyre for my Mach 5 and discussed bringing a pair of overalls and helping them fit ithe exhaust on the lift! They had no objections so with my assistance the job will be perfectly executed! Laughing After all it's my truck and I don't want a single blemish or scratch (put on by anyone else but me that is)! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #54522 22nd Jan 2011 3:23pm
fekete
Let us know how you get on and the sound difference---WHISTLE you get out the turbo
Get a photo of that TD5 project Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #54523 22nd Jan 2011 3:31pm
K9F
Will do on both counts! Douglass had a TD5 system on a display stand and it looked great! As I like to see before I buy that's why I went for Griffin! Their website is a little dated with no mention of the Puma! James the owner was very helpfull and full of good advice! I got a good deal too as he wishes to get his system 'out there!' If it does what it says on the tin I'll let you know! Here's the linky fingy:-
http://www.griffinperformance.co.uk/index.htm
The wheels on their TD5 Karlos makes ours look like tiddly winks! Think they may even be bigger than BigSteve's! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #54551 22nd Jan 2011 6:14pm
K9F
Griffin exhaust fitted today, extra torque noticeable and exhaust tone throatier especially uphill! Helped with the swap out and despite removing front crossmember and disconnecting the propshaft the cat was a complete b4st4rd to remove! Came out in one piece and have complete old exhaust system cluttering up my garage! Heat shield for turbo after removal of cat on to which it was bolted was a little insecure and rattling, quick trip to marine chandlers for a large stainless jubillee clip and a little alteration to the heatshield and it's resecured with no rattle! Job jobbed! Thumbs Up
As an addition - Did a prolonged journey and the engine runs between 6 and 9 degrees cooler! Suppose it's due to the catalytic converter that used to run cherry hot red no longer being there and the reduced back pressure! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #55938 31st Jan 2011 7:50pm
K9F
Picture Addition....
Am awaiting extended front mudguard brackets from Entreq and once the rears are available in three to four weeks time will adapt new rear nearside mudflap to fit as exit pipe sits slightly higher than original.
Post #56873 5th Feb 2011 11:18am
LESVOSD110
I trying figure out if I have a cat or not.Do Pumas have a O2 sensor when cat is fitted.Thanks Puma 110 SW
90 V8 SOFT TOP
Post #57094 6th Feb 2011 12:05pm
Naks
On mine the O2 sensor is not connected & is hanging by the gearbox. I also banged on the cat itself and it sounds hollow, whereas on the A3, when you knock on it, it sounds like it's solid.
Post #57100 6th Feb 2011 12:46pm
Page 3 of 5 <12345>
