![]() | Home > Td5 > Another sound proofing query |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 ![]() ![]() ![]() |
Hi all.
Looking for options re sound proofing the bonnet. There is a number of these items available on the Bay and other suppliers . Bonnet sound proofing/insulation pad - AWR4i47. http://www.brit-car.co.uk/product.php/8243...ad_def__la Many advertisers on the BAY state it will only fit bonnets which came with factory installed fittings, ???? The Brit car add shows spacers, washers and a bracket, looking in Microcat it states 9 spacers and washers, two brackets, assuming these fix to the bonnet bracing panels/double skin, is it viable to fix with rivnuts , possible making the spacers out of thick wall tubing, large penny washers, brackets out of ally strip. Is it a flexible metallic/foam/fabric or a rigid composite, and of does it work. Any info gratefully received. EWS. |
Similar add, upto 06 so that's a TD5.
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...SwZd1VdZod Defender Bonnet Insulation Panel Price: Now Only £84.95! Land Rover Defender New Bonnet Insulation Pad Please check to see if your vehicle has the mountings to fix this panel to the bonnet, some models didn't have these panels fitted in the factory from new. If your model doesn't have them then this will not fit... Suitable for: Land Rover Defender 90, 110 & 130 All Models (1987-2006) Not for Puma Colour: Black AWR4147 / MUC9850 Condition: New OEM Part Warranty: 2 Years |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3236 ![]() ![]() |
Believe me it is no use for the TD5 bonnet.
I have a 2003 TD5 90 and a 2005 TD5 110. I bought one, and tried it! There's no way to make it work properly. The TD5 bonnet edge has no lip at the sides and that soundproofing sheet is just no good. The supplier sold it to me as TD5 compatible and l had to send it back. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
And.... if you think, "Ah, I'll just get an earlier 200/300Tdi type bonnet and fit that" then you'll find that the soundproofing will touch (quite firmly) onto the plastic rocker cover thing (which itself is also insulated for soundproofing) and you'll get a helluva racket vibrating through the bulkhead.
I had a military wolf (300Tdi) bonnet on my Td5 110, and even without the soundproofing it still vibrated on the top of the engine. Got a Td5 one from Ibexman and it made the vehicle instantly quieter. |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 315 ![]() ![]() ![]() |
I wouldn't spend that much, £50 to do the bonnet with foil backed bitumen and self adhesive 20mm closed cell heat proof foam.
http://www.ebay.co.uk/itm/Self-Adhesive-Cl...SwyKxXhPTr ![]() Click image to enlarge I know its the roof..... ![]() Click image to enlarge Sandy |
Thanks to all that replied.
You never know till you ask, the collected knowledge on here is a wonderful resource. Again many thanks to all. Edward (EWS) |
Buy the NK TD5 underbonnet kit, about £50 and does make a difference.
Or make your own pieces and stick them on, as above. |
