Home > Puma (Tdci) > air filter
ickle
air filter
Microcat seems to be off line - does anyone have a diagram of the filter mounting brackets - especially the one riveted under the wing??
Cheers Keith
Post #570896 14th Oct 2016 8:52pm
dorsetsmith
http://cat.lrparts.ru/
this one is work
Post #570899 14th Oct 2016 8:58pm
ickle
No - tried that all I get is FORBIDEN!
Post #570901 14th Oct 2016 9:04pm
dorsetsmith
Post #570905 14th Oct 2016 9:17pm
ickle
Thanks again DS, I found that one but it doesn't show the inner wing riveted bit.
In replacing the viscous fan pulley and bracket today, it was necessary to remove the alternator, to get the alternator top bolt out, I had to move the inlet pipe, to move the inlet pipe I had to release the air filter box which as I've got A/C I can't actually get out and see what is underneath.
So..... Bottom bracket is OK, 2 vertical lugs and three bolts through the inner wing, I drilled the 6 rivets out from under the arch but I cant relocate whatever they were attaching to, hence the need for a photo or a diagram - if that all makes sense!!!
Thanks again
Keith
Post #570909 14th Oct 2016 9:24pm
Keith - The rivets go into predrilled holes in the plastic bracket.
The plastic bracket fits directly on top of the plastic inner wing. It the has I think it's two rubber mounts of which the airbox sits into.
Bes to detach the bracket from the airbox, then river it in place and then fit airbox once bracket is fitted. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #570912 14th Oct 2016 9:37pm
Here is a couple of photos that might be of use?
There is an additional plastic bracket not pictured that sits on the plastic wing you can see with holes in. ____\We|Will|Win/___
Post #570913 14th Oct 2016 9:43pm
ickle
Thanks Steve,
I will have to try and fiddle it into place in situ, then finger cramp through the holes and rivet when all is assembled as the aircon pipe wont let me remove the box. I was looking for a diagram of what the bracket looks like so I could grope with confidence!
Just knowing its made from plastic and the exploded view in DS' post help.
Cheers again.
Post #570914 14th Oct 2016 9:44pm
Roy5695
I have had the airbox out many times and never had to drill any rivets out Confused 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #570915 14th Oct 2016 9:47pm
Thumbs Up I don't have aircon so more access for me.
I can understand what you mean, the bracket sadly I don't have a pic of.
But it's semi triangular to fit snug against the inner wing leaving a support for the airbox.
Good luck. Thumbs Up ____\We|Will|Win/___
Post #570916 14th Oct 2016 9:49pm
ickle
Thanks Roy,
Yes have done searches and read various posts, I think with the aircon pipe straight across the top of the opening it limits the options, also being made of the normal high quality plastic LR are famous for, some can be brittle.
Keith
Post #570919 14th Oct 2016 9:50pm
Roy5695
Yes the aircon pipe is a pain but it can be done, although its probably easier to solve a Rubiks cube!!
And yes the plastic isn't the best, as I've said in previous posts i have broken a couple air boxes getting them in and out... patience and finesse, two things that i run out of quite quickly! Rolling with laughter 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #570921 14th Oct 2016 9:53pm
ickle
Its probably my fault, bracket and bearing arrived today - great service from LR parts again - had a quick look and thought no problem an hour and it'll be done Rolling with laughter
Never saw the two bolt holes at the bottom corners that secure to the side plates on the block BARSTEWARDS!!!
Post #570925 14th Oct 2016 9:58pm
You can indeed either take the rivets out and remove he airbox and bracket adjoined.
Or pull the airbox off rubber mounts as suggested.
Pulling airbox off is more prone to damage in my opinion but the rivets can be a pain I know.
I went for the latter but each to his own. Thumbs Up ____\We|Will|Win/___
Post #570926 14th Oct 2016 10:01pm
