Home > Td5 > Bulkhead swap
excossack
Bulkhead swap
Time came to bite the bullet and get the bulkhead swapped. Not having a suitable garage to do it myself, I farmed it out.
Bulkhead purchased from Dan @ Duckworths
Windscreen frame with glass purchased from Thornton breakers
Paint done by a local paint shop
Dinitrol from Rejel and waxed in my shed.
Fitting down by a LR garage not far from me.
Other sundry parts either from Ebay or Dan
Replacement intercooler also being done while car in bits
Picture time:
Old one removed - Rust top left, foot wells along top seam
During removal
New bulkhead after paint
Vent flaps
New one before fitting (the brown stuff is Dinitrol cavity wax)
Getting things lined up
And that is all I have so far 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #570861 14th Oct 2016 6:18pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Looking good Thumbs Up, suprised it was modified prior to paint? Or are you fitting later dash/heater etc? When I did my bulkhead on the wolf I needed to do a few small mods but did them all prior to paint. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #570863 14th Oct 2016 6:25pm
excossack
It will need modding after paint as I wasn't aware of the changes between years. Assumed all TD5 bulkheads were the same. Any bare metal will be treated. 1999 Defender TD5 110
Regards
John M0VAZ
Post #570864 14th Oct 2016 6:33pm
excossack
Parts purchased
Regards
John M0VAZ
Post #570870 14th Oct 2016 6:53pm
I read the post and then the pm. I was about to say what a brilliant idea it is of you putting a parts list up.
Top job. Bow down
Post #570880 14th Oct 2016 7:29pm
excossack
I went through my head thinking what do I need, and then thought, other people might like to know as well.
I should have purchased wheel arch spat clips, head lining clips as well. I am sure there are other bits I should have ordered as well.
Some bits like, heater control cables might not need swapping but the one that controls the lower vent flaps has snapped and to replace needs a bit of work. 1999 Defender TD5 110
Regards
John M0VAZ
Post #570897 14th Oct 2016 8:53pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
What sort of money did the job cost you out of interest?
Post #570900 14th Oct 2016 9:02pm
excossack
Labour to fit or parts? 1999 Defender TD5 110
Regards
John M0VAZ
Post #570918 14th Oct 2016 9:50pm
nfgp
Nice job, i´m also doing it, but i have a question, how did you remove the wiring loom from the ecu?
Regards
Post #571136 15th Oct 2016 10:11pm
excossack
I think the loom was pulled back from engine bay into the front seat area 1999 Defender TD5 110
Regards
John M0VAZ
Post #571174 16th Oct 2016 9:11am
excossack
Progress, dash back in (lower half), steering column mounted, air filter housing, heater matrix, more wiring loom, pedals in place.
Still to do;
wings
bonnet
grill
windscreen
doors
rest of dash board
While the front end was exposed, I asked them to swap the intercooler.
The old one had a small hole in the turbo inlet side so some oil was evident on the front chassis leg (at least that won't rust). Not sure how much difference it will make to the driving of the 110.
Regards
John M0VAZ
Post #572079 19th Oct 2016 5:38pm
dorsetsmith
looking great
have you fond use for these two holds ?
Post #572093 19th Oct 2016 7:04pm
excossack
Blanked off with a plate riveted on and sealed with tiger seal.
Had I known those holes were not needed, I would have had them welded up and sprayed so not visible. 1999 Defender TD5 110
Regards
John M0VAZ
Post #572094 19th Oct 2016 7:08pm
excossack
In addition to the parts listed above, a few Rivnuts were needed to mount the steering column and heater matrix. 1999 Defender TD5 110
Regards
John M0VAZ
Post #572095 19th Oct 2016 7:10pm
mk1collector
Don't suppose you have a pic of the lugs that the windscreen surround sits on? And a wider pic of roughly where they are on the bulkhead. Ray
My build thread
Post #572112 19th Oct 2016 8:23pm
