Home > Puma (Tdci) > Puma Wash wipe stem
foiloman
Puma Wash wipe stem
When putting the front wiper onto intermittent the switch stem hits my knee causing it to turn off.
Does anyone know of an alternative switch/stem assembly I could install which has a vertical bend? This would enable the resting position of the wiper switch to have a higher OFF position.
I had thought of bending the stem but for obvious reasons have not attempted to as do not want to break it.
Any bright ideas?...
Post #5706 23rd Dec 2008 12:59pm
Grockle
Get a Mustuff seat runner set so you sit further back £40.00 job done. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #5707 23rd Dec 2008 1:04pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Mudstuff Thumbs Up
I had them in the ninety now in the 110 they help keep your knees away from the wheel Thumbs Up
Post #5714 23rd Dec 2008 5:20pm
mse
how tall are you!
im 6ft 2 and dont have that problem Mike
Post #5717 23rd Dec 2008 9:39pm
foiloman
I'm actually quite short at 4' 5" but have really long legs!
I'm going to give the Mudrails a go.
Many thanks for the advice.
6' 3"... 2.4 110 XS
Post #5732 24th Dec 2008 12:05pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Hi,
You can make a cheap fix by yourself. If anyone is interested I can post some pics and hints how to make it. The trick is to lift the seat rail 3 cm so you can move the seat further back.
Best regards, Janusz
www.yahodeville.com
Post #5737 24th Dec 2008 9:38pm
MK
yaho wrote:
Hi,
Best regards,
I did the same. couple of washers between the rails and box.
Post #5739 25th Dec 2008 1:59am
evert
Belgium 2007 Defender 110 Puma 2.4 SW Stornoway Grey
Hello, I'm quite interesed in moving my seat a little back. can you post some pictures?
many thanks,
Evert
Post #5745 25th Dec 2008 7:29pm
dgardel
Italy
I'm interested too, please post the pics
Post #5756 26th Dec 2008 5:19pm
Sonic3d
If you use Mudrails the seat is bolted about another 75 - 100mm further back Thumbs Up as you can see in the photo below
Post #5757 26th Dec 2008 5:41pm
yaho
Hi,
Here are the pics of seat extension raills made by myself.
The first shows the maximum I can get.
Best regards,[/img] Janusz
www.yahodeville.com
Post #5794 29th Dec 2008 9:57am
