![]() | Home > Maintenance & Modifications > Chassis seat brack position |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Did you get a response?
I'm looking for the same info! Patrick |
Rad666 Member Since: 21 Jun 2016 Location: North yorkshire Posts: 89 ![]() ![]() ![]() |
Nop knowbody can be araed haha, think il have to find a random parked one and have a look
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
Mine is raised up on stands on the drive at the minute so could measure it in the next couple of days if it stops raining for ten minutes. How easy is it to get a tape to those holes and how accurate does the measurement need to be? You could come and measure it yourself if you are anywhere near. 2007 110 TDCi Station Wagon XS
Im miles away from you sadly and it should be fairly easy to get too and measurment with a tape would do as the holes for the seat bracket allow for abit of movement
I need to touch up a few bits of underseal on Saturday morning, I'll do it then. 2007 110 TDCi Station Wagon XS
Hope you still need this. Lay in a puddle underneath now! It's 57mm from the right hand bolt to the right hand holes. Centre to centre-ish... Looks symmetrical so same on the left. Bear in mind this,was done with a tape measure! 2007 110 TDCi Station Wagon XS
Thank you very much, im doing the job today
All sorted cheers
Glad to be of service
