![]() | Home > Td5 > Experimenting with a heater air scoop - numpty question |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
I would say its designed to replace the original one but if it fits nicely over the original one and looks good then just fit it over the top, it will stop leafs being sucked up and getting stuck in your heater matrix.
Pete. |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
leve the originl on as you'll need that in there when you have to grab ll the leaves out of the scoop
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Another reason why to leave the origional in........ You won't loose it!! Don't you hate it when you try to put something back to origional and you can't remember where you put the part
![]() Glyn ![]() ![]() |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Thanks folks... over the top it is....
Should have had the courage of my convictions on that one but very much appreciate the sense check ![]() |
Scoop fitted.... Would have liked to have counter sunk the screws but the thickness of the plastic prevented it... will teach me to buy tat off ebay I guess
![]() So now the next question...... 1 scoop or 2 ? ![]() Click image to enlarge Second scoop just for cosmetics of course.... ![]() Click image to enlarge What you reckon ??? Jon - 110 td5 [sold]. Currently Defenderless. |
I had the same dilemma when fitting the KBX Scoops! As one who suffers from a slight case of OCD I would propose two to maintain the balance and asymmetry! By removing the blanking plate and fitting the second it would also give more cooling airflow to your engine compartment! If you go through life with your head in the sand....all people will see is an ar5e!!
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
I left the 2nd off as it also allows more cooling air to the enigne, water into the engine and other debris. Mike |
one IMO.
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 ![]() ![]() ![]() |
So whats the verdict....do you notice any difference to the heater? Life is not a rehearsal!
Def 90td5 CSW xs 2006 |
Haven't tried it yet. Will report back tomorrow after work journeys. And I'm being swayed to just leaving it at one. Thanks all for input ![]() |
Would be interesting to see a Defender in a windtunnel to see how the air flows over the wings.
Pleased to report that there was an improvement in the flow of air into the cab. It's not a massive improvement but certainly one that warrants keeping the scoop. What's most pleasing is that the improvement was felt from 30mph upwards, so you don't have to drive like a loon to get the benefit. Jon - 110 td5 [sold]. Currently Defenderless. |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1862 ![]() ![]() ![]() |
Hi Laurie - have you or anyone else seen the effect of a brick in a wind tunnel?
![]() On a dry day, sellotape loads of 2" bits of wool all around the area you want to test, then drive along with someone else videoing the results - real basic DIY wind tunnelling used in the 60s/70s for tuning cars..... Lets us know how (if) you get on with it! |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
Good point, when you drive off with standing water on the vehicle, it doesn't so much blow back toward the screen as straight up onto the top of the screen toward the roof. I suspect the nose creates such a level of turbulence that air just lifts directly at the top of the cab missing out the wingtops all together! |
