Home > Technical > Gearbox rattle
90roy
Gearbox rattle
As the title suggests, the gearbox makes a rattling noise at idle.
Depress the clutch and it stops, lift clutch and its back.
Doesn't seem to do it when it's in gear.
Any ideas?
R 300tdi 90 1996.
Post #569966 10th Oct 2016 10:52pm
Morepower
New Zealand
Yep, Thats the dreaded clutch rattle... If it's under warranty. Get it fired into the dealer for replacement..
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #569973 10th Oct 2016 11:20pm
90roy
It can't be the clutch Morepower as its just been replaced.
Hmmmmm.
It was rattling before the new clutch, and exactly the same after it.
Got to be gearbox, or the garage didn't replace the clutch as they said they did... 300tdi 90 1996.
Post #569974 10th Oct 2016 11:26pm
Morepower
New Zealand
If the clutch has been replaced, Then it could be the input shaft bearing is on it's way out...Some of the better informed on here maybe able to advise on other options... Do you know if the clutch was replaced with the later type?
Good luck
Post #570000 11th Oct 2016 8:11am
If it's the 300tdi in your sig that we're talking about, then it could be the clutch release bearing.
To be honest, I'd be taking it back to the garage and telling them to sort it out. Darren
Post #570003 11th Oct 2016 8:29am
Thon
My old 2.5 NA 90 rattled for the 10 years I and a friend owned it, and it was used hard, regularly, for trialling and towing a 3 ton burger van trailer. It rattled with an old knackered clutch in it, and the same with a brand new genuine one, with new release bearing. It had the LT77s box (presuming yours is R380) but the same transfer box. Neither box received any maintenance except oil changes, and no debris was produced. My 110 200 Tdi did the same.
I'm not saying that your gearbox is necessarily fine, just that they can rattle for years and still function perfectly. The one in my Puma also rattles intermittently but it's only going to be investigated when it either goes bang or becomes unusable.
IMHO life is too short to be striving to attain perfection from a vehicle that wasn't perfect from the factory ....
Post #570025 11th Oct 2016 12:06pm
rallysteve
Post #570183 11th Oct 2016 10:55pm
90roy
I agree Thon, but just wondered if I had a big bill coming. It appears not, thanks Rally Steve, a very interesting link. I can sleep easy now. Very Happy 300tdi 90 1996.
Post #570724 13th Oct 2016 9:23pm
