![]() | Home > Td5 > No battery light - won't turn over |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Click image to enlarge Is fuse 15 ok bulkhead fuse box ? supply to battery light and on to ALT Is engine immobilisation enabled to work ? Last edited by dorsetsmith on 10th Oct 2016 2:17pm. Edited 2 times in total |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
In my experience that means the immobiliser is still active.
Any immobiliser/alarm lamps active on the dash at all? There's the red LED in the speedo, plus the red engine symbol with a lightning bolt through it (this gets triggered when the immobiliser is not deactivated before starting). 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| Soupy Member Since: 05 Dec 2014 Location: Aberdeen Posts: 68
No immobiliser lights. I can switch the immobiliser off with Hawkeye (I think - I switch it off but when you go back in it says it's on again).
Check the fuses on the bulkhead, particularly 8 -> 15.
2015 D90 XS SW |
All fuses are good.
I noticed that if I run a wire from the alternator earth to the body I get a battery light but still won't turn over. |
Eejit award for the day goes to ME!! Fuse 8 - immobiliser = blown. Cheers!! Last edited by Soupy on 10th Oct 2016 3:54pm. Edited 1 time in total |
from the alternator body to the body work ? as alternator earth throw its body work
have you checked chasers to transfer box earth ? Last edited by dorsetsmith on 10th Oct 2016 3:27pm. Edited 2 times in total |
Still no battery light though....
What do they look like and where exactly are they. There was no earth that I could see on the transfer box, there is now because I put one on. transfer box -- chassis. |
| Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 830
Blue relay in the drivers seat box , check this is ok . Had same issue with mine
And turned out it was this relay Have fun be happy |
Click image to enlarge main earth from battery to chassis to transfer box
chasers to body work drivers side |
| All times are GMT |
