Home > In Car Electronics > Blown fuse or not?
caribcat
2013 Defender 110 Puma 2.2 USW Aintree Green
Blown fuse or not?
Just blown a fuse when inserting a bulb into the courtesy light... radio stopped working also but all fuses are OK. Any ideas welcome!
Post #569691 9th Oct 2016 5:44pm
dorsetsmith
Fuse 29P 10amp is conman to both radio, Interior light and also Link FL5 30 amp in main fuse box
Post #569697 9th Oct 2016 5:57pm
Balvaig
Happened to me too. Interior light and radio on same fuse. It will almost certainly be a blown fuse. Swap over the fuse for these circuits. Can't remember which one but in main fuse box.
Post #569698 9th Oct 2016 6:00pm
caribcat
Have tested every dammed fuse in the box and all good! Interior light, radio, clock not working. Trip resets ever time the ignition is off. Worth mentioning that when the fuse or whatever blew, I'm sure I felt through my arse sat on the drivers seat. Cant imagine there is a solenoid in line...
Post #569834 10th Oct 2016 10:45am
dorsetsmith
do you have multimeter to check for dc voltage in the cct
Post #569835 10th Oct 2016 10:58am
caribcat
Mr. Green Bloody hell, I can be complete Censored at times. Really don't want to say what I've done, just take it that the problem is sorted. Thanks for you input.
Off to stand in a corner for a while....
Post #569837 10th Oct 2016 11:07am
dorsetsmith
go on at lest you sorted now Thumbs Up
Post #569840 10th Oct 2016 11:13am
Cupboard
I'm really curious now.
Were you looking in the wrong fuse box or something?
Post #569854 10th Oct 2016 12:40pm
paulas
what was it I have the same problem, fitted new bulb and radio, clock, interior lights don't work and tacho resets but fuses seem ok. Sad
Post #753101 22nd Jan 2019 2:32pm
dorsetsmith
make shore you voltage to and from the fuse Idea
Post #753102 22nd Jan 2019 2:39pm
paulas
also the needles on the fuel gauge and rev counter don't return to zero ??
Post #753103 22nd Jan 2019 2:43pm
dorsetsmith
also check the earthing battery to chassis to transfer box
Post #753104 22nd Jan 2019 2:48pm
dorsetsmith
2.4 or 2.2 Question
also check fuse 30 and 15 for 2.4 / fuse 4p and 29p for 2.2 and voltage supply too at the fuse Exclamation
Post #753106 22nd Jan 2019 2:55pm
paulas
thanks its a 2.4, strange but I when I was knelt on the passenger seat changing the bulb I noticed small amount of smoke come from the side of the seat and electrical smell.
Post #753114 22nd Jan 2019 3:38pm
paulas
fuses seem ok. I had a new pioneer system put in a week ago. Don't suppose that has anything to do with it, would there be a separate fuse? forgive me if I am talking rubbish but I am not electrically savvy!
Post #753117 22nd Jan 2019 3:53pm
