Home > In Car Electronics > Voltage drop and other rewire queries.
Welkman
Apologies for the spate of posts !
Just adding a 12 volt/10 amp outlet at the rear of 110 towards the door. I have run the calculations and at 10 amps I would need 4mm^2 cable to keep voltage drop < 3%. Does this sound like overkill for a car? All my wiring previously has been on boats with much longer runs. This would also make the cable sizing for the 3 amp load work lights around the 1.5 - 2.0mm cable size allowing for 5m of cable.
Second question: I have a feed into the dash area from my aux fuse box that I want to use to power switches that will only run relays. If I had say 5 switches fed from this one feed and I popped a 3 amp fuse in to protect the cable do you think it would be adequate. Also Do you think that the earth feed from the same (1mm^2) cable would be sufficient to earth all the switches for illumination only? I have tapped into the large cable feeding power to the other standard switches for illumination as I felt this was large enough to take the load of another few LEDS.
Cheers James
Post #569609 9th Oct 2016 10:19am
That does sound like overkill and can only think that there's something not quite right with your calculations. Standard automotive 28/.30 2mm cable is good for 17.5amps and the volt drop over the length of a Defender should be negligible. Darren
Post #569614 9th Oct 2016 10:44am
Welkman
Hi,
Im using this calculator and recommendation to keep below 4% drop.
http://www.12voltplanet.co.uk/cable-sizing-selection.html
Post #569620 9th Oct 2016 12:17pm
I'd tend to agree with LRA above, I'd go for 2.5mm thinwall myself.
Earth should be the same dia, the earth loop is just as critical as the live feed in the circuit. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #569624 9th Oct 2016 12:43pm
Welkman
Well I just found a permanent live and earth in the rear drivers side behind the light panel so I may well just use that, looks like a 12 v feed for an aux socket. Will combine it with my new speaker panels. Thumbs Up
Post #569626 9th Oct 2016 1:41pm
Cupboard
There's a thread about that. it's 20A fused and I'm pretty sure it's 2mm^2.
http://www.defender2.net/forum/topic20319.html
LED worklights will be much less sensitive to voltage drop than standard ones because they are regulated so constant brightness until they stop working.
Post #569692 9th Oct 2016 5:45pm
Welkman
Thanks for the help on this. I am going to use that feed in the back for a permanent 12 volt feed but might add a local illuminated switch so I do not leave it on.
I now have an issue wiring up my carling switches.They have three terminals that control the basic switch (on/off) and then two sets of terminals that control the large light and the small 'bar' light. I think I should have the bar light LED switching on with the vehicle lights (easy) but would like the bigger light to illuminate when on. The question is do I just jumper the switched live to the lamp live or is there a circuit inbuilt to do this like on other switches?
Thanks
James
Post #571059 15th Oct 2016 5:42pm
