![]() | Home > Td5 > Exhaust Manifold |
I might be wrong but can't you just remove the manifold and get it skimmed flat at an engineers? It shouldn't warp again surely. Ray
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
Agreed, it should not warp again and you can get the longer studs separately. And more importantly, how'd you know his name was Shirley?
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Deerfold Member Since: 28 Aug 2016 Location: Shropshire Hills Posts: 54 ![]() ![]() ![]() |
Indeed guys, that would be an easy option but I can't really be without the truck, hence remove the old and replace with an already fettled one.
You could buy a second-hand manifold and get that skimmed and de-webbed before dismantling the vehicle. Studs etc are easily obtainable, but if you de-web the manifold there is probably no reason for using longer or stronger studs.
I have a spare un-modified TD5 manifold in good condition (and seemingly unwarped) surplus to my requirements which I haven't got round to advertising on here yet, I'd probab;y be looking at something around £45 plus p&p if it is of any interest. I bought it to use on my Disco 2 but then bought one already machined. |
Thank you very much for the offer but I really want a manifold that has already warped and then fettled as it is a lot less likely to go again!!
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
Mine went a little while back, a friend had purchased a genuine warped manifold from eBay that the seller had de-webbed then machined so i was able to buy that from him. It's held up perfectly on a 3,000 mile trip around Europe last month, despite being pushed hard for long periods in the Alps. The only thing to note is that the paint isn't high temp so will peel off on the first long joruney.
http://www.ebay.co.uk/itm/LAND-ROVER-TD5-M...XQ1ZhTev3~ At the same time I fitted the Wurth studs that several people recommended, they are a Mercedes part but fitted perfectly. http://www.ebay.co.uk/itm/like/30122372977...rid=229508 2 of the original studs had sheared in the head but once they were out it was a very simple job. If you don't already have them then buy a set of easy outs and a couple of 3mm and 6mm drill bits as a precaution. There's a handy how-to guide that I used, the workshop manual was useful for the torque settings also. The only bit I did differently was to loosen the turbo-exhaust bolts but leave it in situ and split from the manifold in the engine bay. http://alex.threlfall.me.uk/?p=19 ![]() Click image to enlarge |
Thank you, that is great, I shall get one ordered up and and the studs. I have some easy outs but I may just get a couple of spare drill bits!! Do you have the torque settings? Many thanks again.
The manifold studs are 25nm as are the turbo to manifold ones. Afraid I can't remember the other ones off hand.
http://workshop-manuals.com/landrover/defe..._manifold/ The Haynes book of lies has a page of all the TD5 engine torque settings if you have one of those ![]() |
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 ![]() ![]() |
That's what friends are for eh ? Harry.o
Thread resurrection time
![]() ![]() ![]() Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 ![]() ![]() ![]() |
Would you advocate de-webbing a manifold if it was coming off for any other reason, got to sort out my core plug under the manifold on the side of the head? Certainly de-webbing would make it easy to remove a core plug if it leaked again.
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Have heard much about de-webbed manifolds. What is it exactly? Any before and after pics to help the less initiated visualise what is going on? What is the benefit of doing such a thing too?
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
De-webbing and re-skimming and re-fitting with longer studs & spacers/washer and copper flashed nuts means a few things
De-webbing - The idea is the manifold can move/flex under the heat created and prevent it from warping Re-skimming - Gets a warped manifold flat again Longer studs - Enables you to fit spacers/washers which allow it to flex more Copper flashed nuts - Means you can remove the nuts without sheering studs to remove the manifold much more easily. ![]() Thats the one I have fitted to my 110, no issues what so ever so far. |
