Home > Maintenance & Modifications > Nakatanenga rear 3rd stop light
Page 4 of 5 <12345>
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
Ah OK Thumbs Up
Can you make a brighter rear top light especially for tinted windows? That would be good Thumbs Up
Post #567233 28th Sep 2016 8:55am
nakatanenga
Germany
Of course we can....MOQ is 1000pcs WANTED:
SII or SIII in max 1.5k
Post #567235 28th Sep 2016 9:08am
dgardel
Italy
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #568623 4th Oct 2016 4:22pm
ericvv
Post #568625 4th Oct 2016 4:30pm
dgardel
Italy
It's very bright, I taken the photo with the sun in front of me.
Compare with the lower stop, they are the JWS and they are very very bright.
I'll try to take better pics Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #568628 4th Oct 2016 4:35pm
Riverboy
Is your rear window clear or tinted? What colour lens did you buy?
Post #568631 4th Oct 2016 4:40pm
ericvv
dgardel wrote:
It's very bright...
Good to hear, looking forward to more pictures. Mine arrived from Germany to Belgium, it will be end of the month before someone will bring it back here so that I can install it then.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #568636 4th Oct 2016 4:53pm
dgardel
Italy
My windows are the standard light green LR tinted glass, no film.
The lens color is the crystal clear, look at the first post (page 1). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #568674 4th Oct 2016 8:20pm
K9F
Riverboy wrote:
Thumbs Up Thanks Ken. So would Masai, VGS and Bowler knowingly break EU regs?
I also have VGS tinted glass. MOT rules here state they are legal as long as 50% of the light shows. They mean here if it has 6 filaments/bulbs/LEDs and three are out it will pass, 4 it will not, there is no mention of luminescence or light loss through tinting. There is no mention of E markings or anything else. Should the light be electrically disconnected it is not a fail as they are not obligatory. If electrically connected it must operate as above or it is a fail.
As for the rest of the EU I cannot comment but we all are aware I think how strict the German TUV rules are? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #568763 4th Oct 2016 11:13pm
leeds
High Level brake light, safety brake light, third brake light, use whatever description you like.
Now I have not got time or energy to trawl through EU regulation 48 however Hella have done a useful legal guide on vehicle lights here
Page 17 on safety brake light
Quote:
Mandatory for all M1 and N1 vehicles, category S3.
Exception: chassis with cab and N1 vehicles with open
storage space. Authorized for all other vehicle classes.
OK no specific mention of them being type approved/E marked in that Hella guide but IF obligatory under EU 48 then I would guess has to be E marked as Peter mentioned earlier. Also gives m.
in and max light output.
I do not know what date/amendment of the third brake light come into force. However if there is a factory fitted light I would assume it would have to work.
MOT guidelines talks about additional stop light light. What is meant by additional? An aftermarket light fitted by the car owner or the third brake light factory fitted?
As far as I am aware the Nakatanenga rear high level brake light is fully road legal as a replacement unit for the factory fitted 3rd brake light.
Brendan
Post #568769 5th Oct 2016 12:03am
nakatanenga
Germany
Our 3rd brake light has full approval as replacement for the OE one AND full approval to be fitted to all road vehicles as well.
EU rules for lights: If it is there, it has to have an E-mark and it has to work. WANTED:
Post #568792 5th Oct 2016 7:43am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Just fitted mine with a small electronic modification-
Post #569188 6th Oct 2016 8:47pm
Stacey007
^ I don't get that? looks like the brake light is flickering on and off almost faulty...? then comes on..
Is that the modification or am I missing something?
If its meant to be like that I would not like to follow you at night on a twisty road...
Post #569197 6th Oct 2016 9:22pm
nicks
It's a mod. When you first brake it flashes to gain more attention to the vehicle(s) behind, then stays solid, even if you brake again within 10 secs.
With a BAS 170 AB remap you wouldn't be following for long. Laughing
Post #569199 6th Oct 2016 9:28pm
Stacey007
170.. is that all Thumbs Up
>>>>>> Move OVER
If your happy then fair play. A night picture although I appreciate hard to take would be good.
Post #569201 6th Oct 2016 9:42pm
Page 4 of 5 <12345>
