- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > So how did you torque your swivel to axle bolts? |
Harry.O
It's tight but does just fit thankfully. Ah quite right, it has a normal ring on tother end, cracking the original bolts involved a tube over the spanner and it held up well
4th Oct 2016 2:00pm |
jfh
Roy5695 wrote:There is a calculation to work out the required torque setting when using an extended arm...
(torque amount multiplied by length of torque wrench) divided by (length of torque wrench plus length of extension)
All length measurements should be taken from the centre of the pivot point and a pre determined point on the handle, sometimes have a mark or is stated in the leaflet that comes with it (or the middle of the hand grip)
There is many how to's on google with diagrams
If you put the crow foot at 90° in relation to the torque wrench, you don't need to use the calculation.
I think the calculation will prove this.
4th Oct 2016 6:51pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
