|  | Home > In Car Electronics > High Level LED brake light |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | Feeding the wire up the door frame and out you'll have fun with.     I'm assuming you are using the standard wiring rubber boot to gain entry to the door? | ||
|  13th Sep 2016 7:19pm |
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391      | Yeah, standard as far as I can go without drilling more holes.. ...  ,-------,
 .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB | ||
|  13th Sep 2016 9:31pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | Defenders with 3rd brake light factory fitted have a hole up there with grommet in I'd imagine?
 Needs a cable puller or a homemade type of puller to get it through. | ||
|  13th Sep 2016 10:53pm |
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391      | Nah... The feed is by the heated screen printed tracks... Wires exit the door at the bottom of the window...   ...  ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB | ||
|  14th Sep 2016 8:42pm |
| Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113    | Just use
 http://www.3rdbrakeflasher.com/brake-light...p-183.html it also has a G-sensor. Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold | ||
|  15th Sep 2016 8:09am |
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391      | Yeah, I could do that, but I where's the fun? I like messing with microcontrollers and accelerometers!
|  15th Sep 2016 10:02pm |
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391      | I aint forgot about finishing this post.. Just waiting on some fresh LEDS to turn up..
 The last panel had me f*ck up, and put 26 volts thru it! OOPS!!!  ...  ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB | ||
|  3rd Oct 2016 10:35pm |
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391      | Well, I finally got around to butchering the high level brake light to fit the LED panel...
 Here's a pic of the back of the board almost bolted into place! I was too keen to get it fitted to take any more pix!   Click image to enlarge ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB | ||
|  5th Mar 2017 12:20am |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069    | Good job shax, neat soldering    | ||
|  5th Mar 2017 6:25am |
 A few more pix of the LED brake light panel...
 I re-made the brackets this morning to give a better clearance, and then went out and re-fitted the bits as shown in the pix...   Click image to enlarge   Click image to enlarge   Click image to enlarge   Click image to enlarge   Click image to enlarge ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB | ||
|  5th Mar 2017 4:09pm |
| Posting Rules
