Home > Off Topic > Sikaflex - compare and contrast.....
I know that there is a huge body of knowledge on this forum, and many Sikaflex enthusiasts within that body. I wonder if anyone can tell me the difference, and any pros and cons, between Sikaflex 512 and Sikaflex 221 for use as a general purpose caravan seam sealant?
I have used 512 with good results in the past, and was about to buy some more, but have been rather confused to see that 221 is also being listed as a caravan sealant. What's the difference and which is better?
Thanks!
Post #568376 3rd Oct 2016 10:04am
K9F
Hi Blackwolf,
There can be many reasons why someone may be drawn to a particular product. Sikaflex 512 is badged as 'Caravan' sealant which will naturally perhaps come at a premium and be ideal for your purpose. Me personally from experience and trade related tasks prefer the 291 variety (which isn't even a listed choice of yours) as it is Marine Grade and used in the harshest environment possible in my view. 221 is badged as 'one component adhesive.'
Personally I would lean to the 291 but that is me. You asked for differences. Datasheets for all three are below, print them off, compare and make a choice would be my avenue.
http://www.uksealants.co.uk/downloads/Sika...-Sheet.pdf
http://www.uksealants.co.uk/downloads/Sika...-Sheet.pdf If you go through life with your head in the sand....all people will see is an ar5e!!
Post #568381 3rd Oct 2016 10:33am
Personally not keen on the stuff, however, that company listed above is very good for stuff.
Used them before, very good service. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #568398 3rd Oct 2016 12:21pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Hi Custom90Steve, I would be interested in why you are not keen on Sikaflex, I have used it for years for bonding different materials especially aluminium and not had any problems. I am aware that there are other PU systems for sale which give a good bond. A well known Land Rover Series 1 restorer I know uses it exclusively for bonding aluminium together.
Post #568403 3rd Oct 2016 1:02pm
Zagato
What are you plannig to use if for?
Careful as some Sikalfex hardens like concrete. Not always the way to go in some areas of a Landy body that flexes and you have a hell of job getting it back off again. I have used 291 on my boat for permanent, non flexing jobs...
Post #568407 3rd Oct 2016 1:17pm
Repairing some minor seam leaks on a tin tent, hence the 'caravan' references.
I have used 512 before for this purpose with good results, and I am aware that it is now used by many manufacturers during assembly. I hadn't until today come across any references to 221 also being aimed at caravans, hence the question.
Thanks K9F as always for the links and info. Thumbs Up
Post #568421 3rd Oct 2016 2:33pm
K9F
defender9 wrote:
Hi Custom90Steve, I would be interested in why you are not keen on Sikaflex, ........
Me too! I work in the marine industry and it is used prolifically not with good results, but with great results if you know what you are doing of course!
Very Welcome BW. Having used 512 with good results I suggest you stick to what you know, to get.............
Good Results! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #568429 3rd Oct 2016 3:55pm
I'm not a fan of how it skins and that it isn't quick cure.
But if it works for you go for it. Thumbs Up ____\We|Will|Win/___
Post #568445 3rd Oct 2016 6:00pm
