Home > Maintenance & Modifications > Winter general prep-Puma wipers
As the cold/wet weather approaches, I'll be doing loads of little stuff, that's easy for anybody to do and hopefully prevent some breakages.
I decided look at the wiper spindles on Mrs Greeni's 90, as I've had friends whose wiper mechs had snapped off for some reason, and I'd seen loads of rust from the spindles running down the vents (I mean faux vents Mr. Green )
So I decided have a look and it appeared one nut holding the spindle on the bulkhead was loose and the other was not even on the threads making the spindle move around a lot.
Here's how to:
13mm nut holding wiper
The wipers were a bit stubborn, so give them a squirt of Wd40 and have a coffee whilst it soaks in, then give them a jiggle...or if you have a wiper puller.....
The spindle needed pulling out as there were no thread to wind the nut on, so I put the wiper nut back on and used it as a handle to pull the spindle out of the bulkhead
You need a 19mm multi ring spanner or socket as the nut is 8 sided on the spindle, not the usual 6.
The rubber cover I decided fill with marine grease, as they were dry and I gave the spindle a smidgen of grease too, so next time the wiper won't be a bitch to get off.
Then bolt the wiper back on, don't go mad tightening it up, a small ratchet will be ample...don't over do it.
Go and have a look at your spindles...make sure the nuts are holding them on Thumbs Up
Post #568198 2nd Oct 2016 11:07am
ericvv
That's a great explanation. Thanks for that. Surely one day will come in handy. Thumbs Up
Mine are ok I think, nothing loose, no strange sounds. Just this morning, also as winter general prep, I put ACF 50 everywhere I could on the wiper spindles, let the wipermotor with the wipers off the windshield run for a while in the hope that the ACF50 will penetrate some.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #568210 2nd Oct 2016 11:33am
dorsetsmith
good thing for all defender wipers Thumbs Up old and new
Post #568226 2nd Oct 2016 2:38pm
mick
I had all the wheels behind the dash replaced last service as they can part company after time Whistle
Post #568243 2nd Oct 2016 4:54pm
familymad
Re: Winter general prep-Puma wipers
Mmmmmm. Snap on .... 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #568276 2nd Oct 2016 6:29pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Greeni has a good taste in tools, mmm, tool envy Laughing
Post #568285 2nd Oct 2016 6:40pm
Don't get too envious, I only have the one Whistle
Post #568289 2nd Oct 2016 6:45pm
Cupboard
That looks like a Bahco ratchet to me.
Post #568360 3rd Oct 2016 7:11am
AMBxx
A wiper puller - the things I didn't know I needed. Bow down
Post #568365 3rd Oct 2016 7:51am
