![]() | Home > Technical > 2 stroke oil |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
So whats the deal then, mineral or syth ?
How much oil per litre of diesel ? Pom |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
Mineral or semi-synth.
5ml of 2 stroke per litre.
![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
Thanks I need to fill up before laning on Sunday, will give it a bash
![]() Pom |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4810 ![]() ![]() |
Glad to hear that the mineral JASO FB SPEC is O.K. for the Puma. ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
These guys say to use 0.2ml per litre?
Pom |
According to the Aussie thread should only use FC rated if you have a cat. Pom |
Cheers for that. I am correct in assuming that the Puma has a cat? 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
All puma's have them as far as I know. Some threads here about de-cat pipes and such.
Pom. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Incorrect. Pumas in SA do not have the cat. Although the pipe is there, the internals are not and the oxygen sensor is not connected. Look on your gearbox on the side closest to the exhaust. If you see an unconnected plug there, it means you don't have a cat. |
Puma with CAT have not oxygen sensor Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 ![]() ![]() |
yes iam still useing it it is lot quiter more power and i am using castrol mineral 2 stroke oil for motor bikes it is going really well cherrs tim
Just filled up and slapped in some, going for 0.2ml per litre to start off.
This from Halfrauds, correct spec and £9 quid a liter ![]() ![]() Click image to enlarge ![]() Click image to enlarge Pom |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 ![]() |
I also use 5ml per Liter of diesel...
I'm using 200ml of diesel per tankful of two stroke, seemed to work the engine went really quiet.........really really quiet, in fact you can't tell it's running. Original Member Pie n Pea Club.
110 HCPU Tipper |
