![]() | Home > Td5 > Down on Power |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 971 ![]() ![]() ![]() |
Have you plugged it in and are there any codes? Try that first if not already done. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Unplug the maf and have a good run, also did you change the injector loom if there was oil in the harness?
Edit, just seen you've changed the injector loom. Ray My build thread http://www.defender2.net/forum/topic17615.html |
Ojp26 Member Since: 01 Oct 2016 Location: Newcastle upon Tyne Posts: 2 ![]() ![]() ![]() |
Thanks I will try unplugging the MAF and see I replaced it less than 3 months ago (using a genuine part). I guess any crap going through could have knackered it.
Unfortunately I don't have a code reader, however I might have to look into getting one. |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 ![]() ![]() ![]() |
Sticking wastegate on Turbo?
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2215 ![]() ![]() ![]() |
Clean the MAP sensor as well.
When you fitted the bypass pipe did you use a gasket and is it properly torqued up and fully connected? You can check the MAF is working with a voltmeter, I believe Paddocks have a video on their website showing how. Also check there are no splits in the intercooler, usually shows by excess oil showing. |
