Home > Puma (Tdci) > The 3rd Ladybird Defender has hit 200
noworries4x4
4 yrs 4 mts old and its made it the big 200. That's the 3rdLadybird Defender to do it. Wreg TD5 57reg 2.4 (still going in retirement) 12reg 2.2 loads of life in it yet. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #567907 30th Sep 2016 9:14pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
awesome Thumbs Up
Post #567909 30th Sep 2016 9:19pm
xcentric
what on earth do you do to rack up those sorts of miles so fast?!
Post #567924 30th Sep 2016 9:58pm
noworries4x4
I erect, dismantle, inspect and service tower cranes all across the UK, the 90 is fully loaded all the time with chains and equipment, never has an easy day. If everything is under control you are not going fast enough.
No Worries 4X4
Post #567935 30th Sep 2016 10:54pm
TJ101
I will second that,, !! well loaded
Maybe they should give to the keys to the "new Defender" test mule,, that will give it a good work out !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #567938 30th Sep 2016 11:26pm
bm52
.....and still on the original clutĉh?
i jest, how m�ny have you gone through?
Post #567939 30th Sep 2016 11:29pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
A friend bought one of the first 300Tdi Disco ES's in 1994 and it used to spend it's life towing everything including classic cars and tractors, it was constantly off road and had multiple drivers.
It was meticulously serviced to Land Rover's requirements although most was done by our local Indie, Mike Aitken 4x4 in Ladybank, Fife, very few repairs and the ORIGINAL clutch was replaced at 250,000 miles!
Sadly this new clutch will outlive the old one in terms of age but not mileage as the body is now totally dead at around 280,000 miles and that was after major surgery a few years ago! It is now the Estate hack as no MOT is required.
Post #568038 1st Oct 2016 5:42pm
noworries4x4
I had one fitted while the gearbox was out (would have been stupid not to) to replace a failed clutch slave / thrust assy. There was plenty of friction lining left on it but springs were getting weak.
And I also "assume" Rolling with laughter Land Rover fitted one when the engine went pop (transit oil pump issue) If everything is under control you are not going fast enough.
No Worries 4X4
Post #568157 2nd Oct 2016 8:15am
noworries4x4
Your not the first to say that Land Rover could get a lot of information back from me as a test driver. We would soon spot the weaknesses day in day out. Doubt they would want to see their precious test cars dragging loaded artics out of building sites with all 4 wheels smoking (there is a youtube vid somewhere). If everything is under control you are not going fast enough.
No Worries 4X4
Post #568158 2nd Oct 2016 8:20am
BigWheels
Surprised a 90 is roomy enough! 110 or 130 I would have thought you need. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #571181 16th Oct 2016 10:23am
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
200k on the first or second engine or on both together?
Post #571204 16th Oct 2016 12:49pm
noworries4x4
Actually engine no 3, first on went bang (not literally oil pump failure) 26thou second one 94thou guess what oil pump again. Since then religiously changed oil and filter every 6 thou miles to stop diesil contamination from the dpf regen cycle. Apparently there was 30% diesil in my oil when the last engine went pop. If everything is under control you are not going fast enough.
No Worries 4X4
Post #571230 16th Oct 2016 3:12pm
noworries4x4
On site trying to get the trailer round a 110 or 130 would just be too un-manoverable. If everything is under control you are not going fast enough.
No Worries 4X4
Post #571232 16th Oct 2016 3:14pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
What miles did your td5 do? Did anything major go wrong? 2004 TD5 Defender 90 xs station wagon
Post #571334 16th Oct 2016 8:42pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Lol bit like triggers brush then !
How many engines did the td5 go through? Have fun be happy
Post #572048 19th Oct 2016 3:23pm
