Home > Technical > So how did you torque your swivel to axle bolts?
agentmulder
Kuwait
14mm bihex bolts that are effin tight to take off (partially seized being exposed).
WSM calmly states 73Nm with threadlock to get them back on - but there aint no room for no socket in there Neutral
Do folk grind down a socket (both ends, if need be?) , use spring balances on long lever arms, or just do em up effin tight again and whatevers?
These rotters:
 Solved the bowel problem, working on the consonants...
Post #567240 28th Sep 2016 9:24am
Two alternatives:-
1. Obtain a 12-point crowfoot adaptor for your torque wrench and use that,
2. Don't bother with the torque wrench, since it really isn't necessary for these, they're not that critical.
If you choose option 2, which is the common option, and are worried about being wildly off-target, you can always torque something accessible to the prescribed torque to get the feel of how tight it is and then use this a guide when tightening the joint.
Post #567244 28th Sep 2016 9:35am
agentmulder
Kuwait
Well, they're kinda critical!
But I'll read it as: 'there are so many of them that it's hard to imagine 'tight' not being enough' (and within reason, about the same torqey tightness for each bolt)
I have two wrenches, unfortunately the one with the insert style thingy only goes up to 50Nm, the larger one is standard 1/2" square...
I'll get a feel for it as you say, I'll even do it on the axle with a bit of steel scrap around the right thickness being the swivel flange Thumbs Up
>>edit, actually I see what you mean about the adaptor, interesting - I need to think about how a 'click' style wrench would handle that extra lever arm though.... hrrm Solved the bowel problem, working on the consonants...
Post #567249 28th Sep 2016 9:45am
roel
My guidline is that the length off the spanner is the amount off torque you need.
So full strength off your arm should do it. Laughing
Check after some days or 100km orso again and after another 500 km. Still tight then it is probably OK. Roel
2003 90 Td5 (2009-now)
Post #567259 28th Sep 2016 10:15am
Roy5695
There is a calculation to work out the required torque setting when using an extended arm...
(torque amount multiplied by length of torque wrench) divided by (length of torque wrench plus length of extension)
All length measurements should be taken from the centre of the pivot point and a pre determined point on the handle, sometimes have a mark or is stated in the leaflet that comes with it (or the middle of the hand grip)
There is many how to's on google with diagrams Thumbs Up
Post #567262 28th Sep 2016 10:25am
What I meant of course was that the torque is not critical, not that the bolts are not critical. This obsession with every fastener being torqued is a modern thing, and I imagine is due to the relative scarcity of instinct and common sense in modern society.
Post #567264 28th Sep 2016 10:30am
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
Well said Blackwolf!
I Trained as & worked for many years as a Ford Technician in the 90's (or mechanic as we called it then!)
& the "company" torque wrench only ever came out for head bolts!
Post #567275 28th Sep 2016 11:34am
agentmulder
Kuwait
I personally find that most WSM stated torques or feel less than what expect.
I do like the precision one gets with a set of bolts all equally torqued however, but of course there's a few factors at play there, was the hole/bolt/nut drier than the last? How much copper grease/threadlock was there (which initially acts as a lubricant), was the non-threaded flange aligned well and not binding on the bolt shank so on and etc.
Static vs. dynamic friction (for the double clickers).
Alternate/star patterns, knocking/tapping the assembly.
'Revisit in half an hour'
Rolling Eyes
Anyways, I bought it so I'll use it to justify the $$ Whistle Laughing Solved the bowel problem, working on the consonants...
Post #567276 28th Sep 2016 11:42am
jst
just do them as tight as you can with a single spanner Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #567315 28th Sep 2016 2:02pm
dorsetsmith
as ^ Thumbs Up
Post #567322 28th Sep 2016 2:47pm
A Snap On 12-point long ring spanner is ideal for the job, if you're lucky enough to have one. The extra length allows precise tightening and a good balance to be achieved without having to exert excessive force.
Post #567332 28th Sep 2016 3:15pm
Lotus_esprit_s1
These are very good for the swivel bolts, I've had one for at least ten years now.
https://www.amazon.co.uk/Motion-Pro-08-013...B000WJGXF0
Post #567388 28th Sep 2016 6:17pm
mikeh501
when i did mine this year im sure i read something about doing up hand tight, and then going a further 90deg with a rubber mallet on the spanner.
Post #567978 1st Oct 2016 9:23am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Draper do an extra long 14mm spanner with a ratcheting ring on one end, i picked one up off eBlag for a tenner.
Post #568554 4th Oct 2016 10:08am
You may find that there is insufficient radial clearance round the bolt-head for a ratcheting ring. Remember also that a ratcheting ring will never be as strong as a non-ratcheting one.
Post #568573 4th Oct 2016 12:34pm
