Home > Maintenance & Modifications > Pulling seal and CV needle bearing from sub axle how?
agentmulder
Kuwait
Internal seal needs replacing on front puma era stub axle.
Stuck behind bearing (which is in apparently good condition)
I have a new bearing also, so can damage the installed one if need be. Really don't want to scratch the stub axle internal faces.
How is it done without proper bearing pullers or spendy LRT's??
My 3D printed 'tools' have failed so far Rolling Eyes Solved the bowel problem, working on the consonants...
Post #566941 27th Sep 2016 10:57am
dorsetsmith
http://www.defender2.net/forum/post58741.html
you will find SPECIAL Tools for Land Rover on the link see below
TRT-37-004
LRT-99-004
LRT-54-004
LRT-54-005
Post #566968 27th Sep 2016 12:37pm
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
You shouldn't need specail tools. Support the stub with the bearing facing down but in a fashion so that there is room for the bearing to come out. Then, using a cranked drift (I have a very wee wrecking bar somewhere that I use for such events but the blade from an old large screwdriver bent at approx 30 deg' will suffice) knock the seal and bearing out as one.
Take your time and tap around in 45 degree increments rather than concentrating on one spot.
If your bearing happens to be the one that won't budge the same tool can be used to pass through the seal and act directly on the lower edge of the bearing (rollers out first for ease).
Good luck and take great care putting the new bearing in to ensure it goes in square right from the start Thumbs Up
Post #566977 27th Sep 2016 1:04pm
jst
before you spend hours on it check the prices on new stubs with internals they aren't that much Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #566996 27th Sep 2016 1:55pm
Riccarton
^^^^^👍 Wot he said 👍^^^^^
Post #567055 27th Sep 2016 5:24pm
agentmulder
Kuwait
Thanks guys.
LRTs don't exist as stocked inventory round here - and IMO are priced as if they were a kind of money laundering scheme. Managed to 3D print a nice tool to seat the internal swivel shaft seal though, pretty basic, a large socket wouldn't work as the hex interfered. (maybe a bihex would have worked?)
Anyway, I'll look into new stubs, one of them is a wee bit worn on the internal bearing bearing face, like it temporarily seized for some reason.. Bearing seems fine removed, bin it is however!
Will try pry bar with heat (nothing extreme), or bend one my mother's unused ever drivers after rounding and taping up the pointy end. Push both out as one, see what happens.
The seal replacement is because I found globs and globs of dark globby oil around the stake nut but bearing, yet the grease was still clean on the outer bearing.
Seal looks fine though, as does the old CV seal ring..
Weirder too that the flange still managed to seize itself well and truly to the CV splines. Wot a carry on it was removing that Evil or Very Mad Solved the bowel problem, working on the consonants...
Post #567107 27th Sep 2016 7:55pm
dorsetsmith
Post #567140 27th Sep 2016 9:02pm
agentmulder
Kuwait
18quid and then shipping and the wait?
Once you have a 3D printer it's like Shocked Rolling with laughter Solved the bowel problem, working on the consonants...
Post #567146 27th Sep 2016 9:09pm
agentmulder
Kuwait
That being said, 3D printer failed here...
However, success!
I went for the remove the rollers/race first technique and then drift/caveman technique:
Cheers all, project back on schedule. Although it looks like I might need to print myself a tool to get the new seal in nicely Rolling Eyes Wink Solved the bowel problem, working on the consonants...
Post #567201 28th Sep 2016 1:53am
