![]() | Home > Td5 > Windscreen frame removal TD5 2001 Non-air con |
MC84 Member Since: 23 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
Hi, I need to remove my windscreen and frame. The rubber seal for the glass has failed but also there is some corrosion going on under the rubber and also I'm not confident with regards to how good the seal is between the frame to the body (roof and bulkhead).
I understand I can get the frame out by part lifting the roof/sides of the Defender. What I really need are the part numbers for the seals between the shell (the part I'm going to lift) and the base and the top and bottom seals for the windscreen frame. Have I missed anything else I may need as I want to get everything on hand before I start. I have got the screen rubber and some glass sealant already. OH, and a new screen! Thanks in advance ![]() Click image to enlarge Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
LR055345 - BULKHEAD>WINDSCREEN SEAL / windscreen seal upper inner MTC4994
Hi and thanks for the reply's. Another question if I may; What would you do, pay around £100 for a genuine LR windscreen rubber or buy a Britpart for less than a tenner? Mike
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6726 ![]() ![]() ![]() |
Allmakes PR2 one, not the cheapo Britpart one.
Unfortunately I don't know who they are. Can you elaborate please Martin?
Stop the Press, I found them but looks like Trade only? Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
Allmakes is a parts brand./group, just like Britpart. Supplied to parts companies only for them to retail.
They have a "Premium" parts range, with 2 year warranty on them - this they call "PR2". I would recommend their windscreen seal, have fitted 2 now and they are fine. Just one supplier, there are many others ![]() http://www.totalparts.co.uk/products/lr056...makes.html ![]() ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
bearmach one for me Cheers
Once again thanks Martin and JST for your input. I've ordered the bits I need so fingers crossed!!
![]() ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
