Home > Maintenance & Modifications > Nakatanenga rear 3rd stop light
Page 3 of 5 <12345>
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
No, Brexit was the subject but you didn't like other peoples views Rolling Eyes
Can we stick to talking about these rear lights? I cant be the only one here that has a factory tinted rear window?
Post #567036 27th Sep 2016 3:41pm
mk1collector
I didn't like other people's views? Rolling with laughter Rolling with laughter Rolling with laughter Ray
My build thread
Post #567037 27th Sep 2016 3:43pm
Riverboy
Rolling Eyes oh get over yourself lad
Post #567038 27th Sep 2016 3:44pm
ericvv
There are no factory tinted rear windows with a Defender. At least not the central large rear window in the door, which when you ticked the box for the factory tinted windows was left untinted. The two small rear windows at the side in the rear, the side windows from the B-pillar onward, and the Alpine windows all were tinted, but not the central window in the 3rd or 5th door. JLR must have had a reason for doing so.
Also read below thread....
Eric
http://www.defender2.net/forum/topic30099....ed+windows You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #567051 27th Sep 2016 4:11pm
Riverboy
Sorry when I say factory I didn't mean JLR factory, I mean any factory made tinted glass rather than the after market tinted film, as we have on our other Defender.
Post #567052 27th Sep 2016 4:16pm
Riverboy
So did you go for the Masai in the end Ray?
Post #567053 27th Sep 2016 4:23pm
ericvv
As said, I think JLR know what and why they were leaving the factory rear door window untinted. However, to make you feel better, we have plenty of high spec expensive Merc G Class on the road here with factory (not after market) rear windows tinted, and with those the window in the rear door is also tinted. Their LED 3rd brake light is behind that tinted glass, and I am always amazed how poor the light production of that not unimportant brake light is with those.
But again, in France brake lights must all be optional I think based on what I see on our roads here, so you probably should not worry too much. Rolling with laughter You never actually own a Defender. You merely look after it for the next generation.
Post #567054 27th Sep 2016 4:24pm
The Bowler has VGS tinted with a built in HLBL Thumbs Up
Post #567056 27th Sep 2016 4:26pm
Riverboy
Thumbs Up Thanks Ken. So would Masai, VGS and Bowler knowingly break EU regs?
I'd like to read the actual regulation on this but cant seem to find anything about it at the moment.
I must say that I dont think the tint has much effect of the brightness at all when I compare our two Defenders. The biggest difference is when you compare it to the LED lights which are much brighter, hence me considering ordering this new LED brake light to replace the last non LED light on the car.
Post #567059 27th Sep 2016 4:35pm
A 3rd brake light or HLBL I'm pretty sure is known as supplementary lighting as the rear tail / brake lights are obligatory.
But if it is 'E' marked the light would have been either tested affixed to screen or prior to fitting.
If attached to screen then no problem, if tested prior to fitting then that's no different to timing your obligatory lights as they are legally void as not used as designed for purpose.
Similar to using LED's in incandescent fittings.
If the 'E' mark is on the glass by the light I'd say probably fine and tested affixed.
If not maybe the light was prior tested.
Not an easy one to define!
I think we need a 'GB' mark shortly or BS standard. Mr. Green ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #567075 27th Sep 2016 5:28pm
mk1collector
I've got Masai down the side windows but I haven't got round to fitting the rear ones yet, they still just have the film I put on ages ago. Ray
My build thread
Post #567076 27th Sep 2016 5:34pm
Riverboy
Our other Defender has the film and you do need to look closely to see the difference. Just in a few places around the edges you can tell.
Post #567078 27th Sep 2016 5:38pm
nakatanenga
Germany
If a light is fitted, it needs to work and fully fulfil E-regulations.
What does the e-mark on the window say? It says, that the glass is generally good for road vehicle use in safety and transparency etc. It does not provide any vehicle specific (Defender) allowance to fit.
If an e-marked window does not work together with a factory fitted homologated brakelight it is not allowed to be fitted.
Example: our LED side repeater is generally E-marked as side repeater. it directly fits into a existing hole on a Defender fender BUT it can be fitted to any road vehicle. But only as a side repeater, not as rear or front indicator. And there are fitting rules for side repeaters as heigth, visibility etc. WANTED:
SII or SIII in max 1.5k
Post #567216 28th Sep 2016 6:44am
Riverboy
Yes I have your side LED side repeaters fitted to my car. I have the smoked lens which looks great against the Corris grey body.
Do the same regulations apply to the side repeaters as the rear top light? Because as with the rear tinted glass, the smoked lens on the repeater obviously reduces the brightness of the lamp somewhat.
Post #567229 28th Sep 2016 7:29am
nakatanenga
Germany
With all our LED products the brighness of the LEDs is adjusted to the lens. That means the orange LEDs in a black repater shine brighter (compared to a white one) to compensate the tinted lens. WANTED:
Post #567232 28th Sep 2016 7:42am
Page 3 of 5 <12345>
