Home > Expedition & Overland > Help please sankey hitch bolts size?
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Hi can anyone tell me the size bolts I will need to attach a sankey na to hitch to a slider plate ? Bow down
Post #565634 21st Sep 2016 8:30pm
xpertoftheseas
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Aintree Green
Pretty sure I fitted mine with M10. Measure the 4 holes on the hitch and then measure the length from the front of the hitch to the back of the slider plate, then add 30mm. Use Nyloc nuts to secure the four bolts and use a heavy grease to cover them (or get some M10 plastic caps and put grease in them). If you need pics just shout.
Correction. .. I just measured and I used M12 to attach to the DB saddle. My 10th Land Rover, but my first Defender.
Post #566270 24th Sep 2016 5:43pm
VeeTee
Netherlands
I used M12:
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #566280 24th Sep 2016 5:57pm
Oakseywick
Thanks for the replies I used m12 in the end Thumbs Up
Post #566403 25th Sep 2016 7:52am
Cupboard
All the stuff I've attached to my slider plates I've used M16 bolts because that's the size of the hole.
Not sure I'd be happy with M10 or M12.
Post #566522 25th Sep 2016 5:51pm
Retroanaconda
Four M12 bolts is fine. Use 10.9 or 12.9 grade.
Most important is ensuring they won't just pull through. When I did it I had two pieces of 10mm and 8mm plate drilled to match and put them either side of the crossmember.
Post #566525 25th Sep 2016 6:11pm
VeeTee
Netherlands
^ The proof load for a (single) 8.8 Grade M12 bolt is 48900 N - approx. 4890 kgs - (and 10.9 Grade is 70000 N), so four bolts sure must be enough to pull the sankey? ... Cheers, Vincent
MySite
Post #566526 25th Sep 2016 6:14pm
Retroanaconda
Sure, but why engineer when you can over-engineer? Razz
I was fitting it for different purposes:
Post #566610 25th Sep 2016 9:46pm
miker
Biggest that will fit through the holes. So M16 I believe. 8.8 at least.
Post #566626 25th Sep 2016 10:48pm
