Home > In Car Electronics > Best place to site extra relays around the dash? |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1747 |
You dont say what vehicle you have but assuming Td5 and previous then put them with others on fuse panel infront of gear levers
25th Sep 2016 6:56pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 326 |
yep it is td5. I will have to see if there is enough space there, it looks fairly full.
25th Sep 2016 7:00pm |
Seatbox? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
25th Sep 2016 7:06pm |
Auxiliary fusebox is on the bulkhead behind the passengers seat with live feeds run through conduit to the bulkhead so the ideal place is near the dash or the engine bay.
25th Sep 2016 7:14pm |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 423 |
I have 4 relays situated behind the speaker on the passengers side on the dash on my Td5
Easy to access the wires - just unscrew the speaker Closer than the seat box to run wires to centre of Dash for switches etc |
25th Sep 2016 7:18pm |
I like that plan! I think I have been over complicating my electric window install anyway. It is a 6 feed switch that reverses polarity so I think it just needs feeding from one ignition switched relay and the switches themselves have the full load running through them.
26th Sep 2016 7:12pm |
