Home > Maintenance & Modifications > Fitted my new Wipac Crystals and Wipac side / indicators
Stacey007
OK (and thanks to those who helped quickly to my post about the reflector in the main light)
I decided I couldn't wait....for the rears to arrive...
Headlamps from http://www.paddockspares.com/ I did not know they came with a reflector and side light bulb...
The wipac front sides and indicators from http://www.mudstuff.co.uk/
Bulbs were Philips H4 extreme vision with side light bulbs (handy)
This job I have to say took me 4 hours !! not rushing it at all and a helper (if you can call a 5 year old that). I did however clean / polish the bits I took off and behind them and also sprayed ACF50 over bits while all apart. Pain was a side light in one headlamp not coming on when I tested it unfitted it did.....fitted it and it didn't !! so all apart again and an iffy crimp...
Anyway I'm more than happy with this, looks SO SO much cleaner, smarter. Oddly I've not fitted the Relay yet or the loom but all appears to work just fine? I have rear LED's on the way so will fit the relay tomorrow. I guess a trip to my local garage maybe required to set them correctly although I did try to refit the same (and being honest I think they were out anyway prior to changing)
Before...std lens? bulbs etc
One done with help from my right hand man.. (the sawdust is not due to my car leaking, its under a carport I'm using a saw table to cut sleepers)
I like the way the side lights not light up the headlamps, safer imho more to see.
Still need to fit..
Tools to do the job.
Happy with that Thumbs Up in fact so much so I'm not sure I will go LED headlamps just yet, and I was thinking of that route.
Post #566310 24th Sep 2016 7:49pm
Cool _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #566319 24th Sep 2016 8:06pm
williamthedog
Yep the crystals make a fair bit of difference and it's a cheap modification too Thumbs Up
Post #566325 24th Sep 2016 8:21pm
Stacey007
^ Cheap if just the wipac headlights..... but I haven't stopped there.
4 front lights (sides and indicators)
relay
8 rear lights (a spare fog and reversing lamp if I go 3 each side...)
plinths
cables
Loom
guards
ACF50
Its added up Smile but its safer so that's how I will get this passed Mrs Stacey007
Thumbs Up
Post #566330 24th Sep 2016 8:26pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I went the opposite way, I'd rather people seen me from behind on a dark night and fitted NAS rear lamps, and fitted them with the brightest LED's I could find Laughing
And swapped the indicator position with the tail/brake lights Thumbs Up
I didn't forget the fronts either, mind Whistle
Post #566340 24th Sep 2016 9:02pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Errr, is it not an MOT requirement to have rear reflectors Mikey? Whistle Whistle 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #566343 24th Sep 2016 9:09pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Been mulling this mod over for a while, but now you've confirmed for me it's a must, especially now the winter months are setting in 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #566347 24th Sep 2016 9:18pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
how easy was the Boomslang to fit?
thst is probably my next thing to fit
Post #566352 24th Sep 2016 9:23pm
Stacey007
I wanted to upgrade before winter...
Its already dark around 7.30 so doesn't leave much time home from work in the evening to do and the clocks go back soon. To be honest though coming from a car with bi directional Xenon lights I don't find the lights too bad, I just wanted it to look better also Smile
I haven't done the loom as that worry's me...... Saying that I had to crimp wires together to join the side lights to the headlights, so that was also fun (I don't do electrics....) its in the boot....
All seems good though Smile
Post #566360 24th Sep 2016 9:33pm
Disco_Mikey
Passed just fine, as did the Disco 3 Thumbs Up
All the more reason for bloody bright lights Laughing
It is something that will be rectified during its rebuild though...
Post #566373 24th Sep 2016 10:01pm
mk1collector
Rear reflectors are an mot requirement Whistle Ray
My build thread
Post #566390 24th Sep 2016 11:39pm
MOT testers don't always meet requirements. Whistle
Would 'E' marked reflective tape suffice instead? I'm guessing not and should really be a reflector. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #566394 24th Sep 2016 11:50pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
There was no crimping of wires when I fitted mine other than putting a terminal on for the main power feed. The rest was a case of simply plugging in and picking up a couple of earth's for the headlights.
Post #566416 25th Sep 2016 9:16am
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Are the headlights themselves actual Wipac and just repackaged in a box branded as Britpart "Super Crystals"?
Paddock's website is unclear what brand they are actually selling.
Post #566458 25th Sep 2016 1:22pm
Mine were in Wipac boxes.
There are some versions with a pilot light too. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #566459 25th Sep 2016 1:27pm
