Home > My Defender > 110 Td5 Station Wagon County
qxl
Hi There,
I've recently purchased a 110 Td5 Station Wagon as a bit of a project. Saw it on ebay and well it was reasonably cheap and I won it with a single bid.. Confused
It's in need of some TLC, gearbox was very noisy on the overrun and crawling in traffic was awful despite a new clutch having been fitted by previous owner. So I had it rebuilt at a local specialist, it's now much better, But the noise hasn't totally gone. When the garage had it on the ramp I took the opportunity to give it a look over and there is a lot of play in the front prop shaft. The mechanic also seems to think it's not the correct one for the vehicle. So next job is to get that swapped.
On that topic, I'm not sure in the truck is lifted or not, seems to be sitting higher than my last defender (110 double cab) but don't know if that's down to it being a station wagon or not, previous owner didn't mention it being lifted. What do you think?
If lifted it looks like I have the option of getting a wide angle / double cardan propshaft or fitting standard suspension on a stock propshaft. Car will spend 90% of it's time on the tarmac so I'll want whatever makes it a better daily driver.
Other than that all the doors are rotten and the locks are dodgy, it's got some oil leaks. Will keep me busy for a few months, but I'm happy enough with it.
Post #566238 24th Sep 2016 3:12pm
familymad
Was that the eBay one on a galv chassis? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #566241 24th Sep 2016 4:04pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Welcome, Looks like a good starter, look forward to the updates Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #566245 24th Sep 2016 4:34pm
qxl
No mate, it's on it's original chassis, but did have a new rear crossmember fitted a couple of months before I got it.
Post #566262 24th Sep 2016 5:30pm
qxl
Cheers, got a Mantec Swing away Spare Wheel carrier to fit to a virgin Rear Door. Seems a shame to start putting holes in it, but needs must and I could do with having the spare out of way.
Do you know of an easy way to work out if the truck has been lifted?
Post #566265 24th Sep 2016 5:35pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
Would this help you qxl?
 Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #566269 24th Sep 2016 5:41pm
qxl
Thanks for that, might be able to work it out based on the ground clearance of the front axle... assuming I have the right size tyres. Time to get the tape measure out.
Post #566274 24th Sep 2016 5:47pm
qxl
Actually thinking about it the axle clearance won't help as the suspension sits on top of it.
Of course I realized that after I'd gone out and done the measurements.. So I've got 265 tyres on 16 inch steel wheels, and the clearance was 9 inches at the front and 8 inches at the back. Some reading on suspension lifts in order I think.
Post #566281 24th Sep 2016 5:58pm
