Home > Puma (Tdci) > Slick shift tdci?
Page 4 of 7 <1234567>
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
ericvv wrote:
Wild Card 90 wrote:
Not everyoneīs cup of tea, is it, Eric. I agree, rubber pedal caps fit perfectly to the standard Defenderīs gearshift. Rolling with laughter Stephen
Stephen, I think I won't have trouble to continue to live with my "standard" gearshift sticks. Slow 'n steady, but never missing the right gear. Whistle Thumbs Up
Eric
Eric,
a set of aluminium pedals would suit your Defender perfectly, and match the SVX shift knobs. Thumbs Up
You are welcome to try my sensitive and precise shifting 90, if you happen to wander down in to the flatlands at some point. Let me know.
Stephen 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #565982 23rd Sep 2016 8:13am
Grenadier
WC90, good write up. Certainly think this has been added to the shopping list. Just drove our spare car (Mini Cooper) and holy schmoly you suddenly remember what it's like to drive a short shift gear box. I almost thought it was broken, wondering why the gear stick hadn't moved three feet to the left before finding the gate. An inch or so max. Nice. Thumbs Up So I think I'll take your recommendation, but after I've (Hopefully) slipped in a V8.
By the way, given you're determined to get the 90 to feel like your 911 (let's be honest, they're only a few steps apart..ahem Whistle ) have you considered this as an upgrade?
http://www.bowlermotorsport.com/product/quick-ratio-steering-box/ Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #566104 23rd Sep 2016 6:27pm
Wild Card 90
Gren, i look forward to hearing about your own first impression, when the time comes. Thumbs Up Thumbs Up Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #566141 23rd Sep 2016 9:14pm
Wild Card 90
Porsche and Land Rover. Separated at birth. Both have the ignition key on the left, started building cars in 1948, and have maintaned the same silhouette for nearly 70 years. Now lets keep our finger crossed that JLR doesnīt mess up their part of the deal.
I donīt think iīll be going for that faster rack. Thatīs alot of money. Maybe I need to drop in at Bowlers, like you did, to experience one of their Challenge 90īs.
Driving the Defender today, I actually donīt notice the short shift any more. It feels so natural, exactly how it should be, as if it was always that way.
If I get into a standard one, itīll probably feel like its worn out in comparison. If anyoneīs passing through, and would like to drop by and try mine, feel free! Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #566243 24th Sep 2016 4:23pm
Wild Card 90
For those who might be interested, hereīs a comparison of the standard selector and the upgraded one. The dimensions of the pivot and selector balls are identical. The distance between the the two is increased by 20mm. The difference is accommodated for through the additional spacer supplied in the kit. This lifts the shift lever 20mm higher in the cabin, which is an additional improvement for Defenders running raised cubby boxes and/or padded lids.
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #567946 1st Oct 2016 5:47am
Morepower
New Zealand
Having fitted one myself, I can report a massive improvement in the gear change... I had to strip mine down twice to stop it rattling, But it all seems good now... Just the 110 to fit a kit to now...
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #572650 22nd Oct 2016 2:19pm
acuss01
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Had my slickshift fitted last week, rattles when driving over 60 mph. Is that normal? 2015 110 XS CSW Montalcino Red with Black Pack
Post #572965 23rd Oct 2016 10:51pm
Wild Card 90
Easy to fix. There is a little bit of play between the shift knob and the new slick-shift selector lever. Unclip the shift knob and remove it, then run a short piece of electrical tape aroud the slick shift lever, and refit. It should be enough to take up the play, but not too much, otherwise the shift knob wonīt clip down into place. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #572985 24th Oct 2016 1:00am
pjb
Some feedback having fitted the Slick Shift a couple of weeks ago
It has made the shift shorter more precise, but it is marginal as my defender is low mileage so the plastic had not really worn very much.
If I'm being critical on the negative side I can hear more gearbox noise through the gearstick, as the previous plastic part took did not allow the gear noise to come up the stick, wheras with a metal one you can hear more gearbox noise.
I might need to put more grease inside the gearstick to reduce the noise transmission Thumbs Up 2020 P300 HSE
Post #573003 24th Oct 2016 7:50am
Morepower
New Zealand
It shouldn't be... It's either the weights in the gearstick are loose... Or the shaft isn't located correctly/has enough grease... Mine was the latter two and now it's ok.
Hope that helps
Regards
Post #573022 24th Oct 2016 9:22am
Wild Card 90
I agree. There is no reason for additional noise, apart from vibration between the above mentioned components. Either add grease or electrical tape to fill the gap. Driven mine about 1500 Km, and it is still a noticeable improvement. It doesn't make the shift "slicker" or quicker, just shorter and more mechanical. More Defender, and less Transit..... 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #573040 24th Oct 2016 10:01am
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
Anybody has a "picture of how the electricaltape should stick?", just want to tap to the experience even before i start at all
Post #577882 15th Nov 2016 1:23am
pjb
Well having had it on for 3 months, have decided to remove mine.
I had two problems with mine - bearing in mind my defender has done less than 10k miles, first I did get some gear rumble up through the gear stick, tried insulating tape on the top of the metal stick and more grease, but it was still noticeable, plus my wife struggled getting the car in reverse after fitting the slickshift, so back to standard gearstick which she has no problems with and being plastic you do not get the same amount of gear rumble.
Will probaly keep for when the gear box / linkage wears and then refit to a slightly worn gearbox
In summary I think a good upgrade for worn linkages but on a fairly new vehicle makes a tight gearbox very precise. Thumbs Up 2020 P300 HSE
Post #595821 24th Jan 2017 10:12am
Likeomg
could also do with pics on this anti rattle tape....
fitted mine the two pieces went together very easily, unlike the install video...
rattles like you wouldn't believe... not going to be happy if i have to take it out again, just glued down a brand new carpet set which i really don't want to remove as it will probably trash it.
not too impressed to be honest.. Neutral
Post #600468 9th Feb 2017 9:38pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
mine went together like yours above, very easily and nothing like the video. now get a rattle at certain rev/speed ranges.
Post #600630 10th Feb 2017 12:36pm
